Licensed User
Shuie's Avatar
Need MFI fuel hose part number please
Time for fuel line replacement.
I think I found the part number for the fuel hose that goes from the cold start solenoid to the cold start injectors.
4.5mm ID , 9x5mm OD - 999.180.080.50
What about the rest of the fuel hose running from the tunnel exit to the fuel filter console? Is this the same as the hose that runs to and and then back from the MFI pump? Does anyone have a part number for it?
Im also going to replace my fuel tank. Does anybody have a part number for the fittings that attach to the tank?
Never mind the red mark. pic for illustration, stolen from one of Grady's old posts.
TIA
Old 08-25-2004, 11:59 AM
Friend of Warren
Sherman on my '72E I just used high quality fuel line hose for fuel injection that I got from my auto parts store. They have all the various metric sizes and it is MUCH cheaper than OEM. The rubber lines are not under that much pressure. As for the cold start injection lines be very careful removing and installing the line on the plastic injectors and they are quite brittle and unobtanium!
Kurt V
Old 08-25-2004, 12:08 PM
