Wil Ferch Where is the calculator?
Wil or maybe someone else can help,
Where do I find the ride hieght and corner balance calculator. I am going to change spring plates and bushings this weekend and need to figure this stuff out. Thanks so much Ben |
Friend of Warren
Go here and scroll down to the Porsche 911 Section: http://vintagebus.com/
Kurt V No more Porsches, but a revolving number of motorcycles. |
Gasoline User
Bob V 1974 911 Carrera coupe Grand-Prix-weiß 1977 930 turbo Carrera coupe Hellgelb 2018 Cayenne turbo Schwarz 2019 911 GT3 RS Schwarz |
I know more about what's going on here than most because I supplied the parts. Ben, THIS THREAD IS USELESS W/O PICS!
Insert Tag Line HERE.....
I just used it today when I installed my rear bars. I wont know for awhile if I did it right because the engine is still out
Marc |
Sorry for responding late to this....but I see others have chimed-in for me. Thanks, all.
The calculator seems to work well, but it requires accurate "input" data to get good "output"...not really surprising. Total weight, fr/rr weight distribution is key..... ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Here is the spring plate angle calculator
http://vintagebus.com/cgi-bin/spring.cgi And the corner balance calculator http://vintagebus.com/cgi-bin/balance.cgi
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs Last edited by widebody911; 08-25-2004 at 06:27 AM.. |
Wil, i used it and came up with a spring plate angle of @18 which seems to be not enough. I know the 31 bars are very stiff, but without the engine in the car, its almost where it needs to be now! (the initial angle was @35)
I used the following specs, weight:2200, droop height:3.2, bars:31, and got 17-18 degrees. Well at least I have adjustable spring plates so it will easier to correct if Im off!
Marc |
I'm not going to to do individual situation math checks....
![]() but I will say that if the all the input data is correct ( total car weight....fr/rr distribution which is typically 40/60 for non Turbo....plug in the TB sizes...and assume you're targeting Euro ride height ...about 3.84" spring plate angle droop when car is on-ground).....then...this should all work out to within 1/4" or better of your targeted ride height. Sure beats guessing and doing this whole mess over 3-5 times ! ---Wil
Thanks found it! I will go ahead and tear into it. Anybody now where I can set default for rear alignment when I am done?? Of course I will have it done properly just wanted to know if I could do it myself
Ben |
Another thing to consider: I installed Elephant Racing monoballs and polybronze bushings last weekend, and I noticed the spring plate bolts were kind of haggard, so I replaced all of the hardware with the exception of the eccentrics. The spring plate bolts and eccentrics are 12x1.5mm I bought slightly longer ones and used nylocks instead of plain nuts. I also chased the threads on the eccentrics.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Good idea thats what I will do.
Ben |
