-   -   This sucks. AC delete stalling (http://forums.pelicanparts.com/porsche-911-technical-forum/179353-sucks-ac-delete-stalling.html)
Porschekid962 08-25-2004 03:08 AM
I have ALL of the ac components ripped out except for the vaporator in the smugglers box. I disconnected the hoses, siring and the 10mm nut attached to the hold down strap. The silly thing wont come out. So tell me, where is the bolt that I am missing and how do i get it out????
Thomas Owen 08-25-2004 03:47 AM
It comes out in pieces.
The top cover is held on with metal clips around the edge. Slide them to remove. Remove the clips, then remove the top cover, lift out the evaporator coil. The lower piece of the box can then be unfastened from the car body.
John Block 08-25-2004 04:18 AM
The bi-metallic switch at the base of the evaporator is keeping you from getting the whole mess out. It's located at the base of the passanger side footwell (access from inside the passanger compartment) take out the six screws the arrows point to in the picture.
http://forums.pelicanparts.com/uploa...1093432625.jpg
jakermc 08-25-2004 05:17 AM
To clarify John's picture, this is directly behind the passenger floor board.
Mysterytrain 08-25-2004 06:33 AM
Isn't there also a connection behind the passenger floor board that must be disconnected before you can remove the evaporator?
Porschekid962 08-25-2004 12:14 PM
Thanks guys, its comin out tonight!!!!!
Par911 08-25-2004 01:36 PM
http://forums.pelicanparts.com/showthread.php?threadid=155366&highlight=smugglers +box
Porschekid962 08-25-2004 01:52 PM
well i shoulda done a search on smuglers box's. haha. well its coming out tonight so i can make some templates and block of all the holes with fiberglass pieces. oh the joy or fiberglass and resin, i think it goes along with the porsche way of lightening up cars. too bad it will all be hidden up.
