This sucks. AC delete stalling
I have ALL of the ac components ripped out except for the vaporator in the smugglers box. I disconnected the hoses, siring and the 10mm nut attached to the hold down strap. The silly thing wont come out. So tell me, where is the bolt that I am missing and how do i get it out????
Not Quite Banned
It comes out in pieces.
The top cover is held on with metal clips around the edge. Slide them to remove. Remove the clips, then remove the top cover, lift out the evaporator coil. The lower piece of the box can then be unfastened from the car body.
Thomas Owen 1972 911T 1972 911S |
The bi-metallic switch at the base of the evaporator is keeping you from getting the whole mess out. It's located at the base of the passanger side footwell (access from inside the passanger compartment) take out the six screws the arrows point to in the picture.
To clarify John's picture, this is directly behind the passenger floor board.
1983 911 3.6L - NASA GTS-3 class 1998 Boxster - PCA SpecBoxster, NASA GTS-2 2003 996X51 - NASA GTS-4, PCA GTB 2003 996 Carrera 2 Coupe 2003 Ferrari 575M |
Isn't there also a connection behind the passenger floor board that must be disconnected before you can remove the evaporator?
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Thanks guys, its comin out tonight!!!!!
74 911s neverending story. two feet and a jetta for now. |
well i shoulda done a search on smuglers box's. haha. well its coming out tonight so i can make some templates and block of all the holes with fiberglass pieces. oh the joy or fiberglass and resin, i think it goes along with the porsche way of lightening up cars. too bad it will all be hidden up.
