-   -   8's or 9's? pros and cons please. (http://forums.pelicanparts.com/porsche-911-technical-forum/179952-8s-9s-pros-cons-please.html)
Dave Nordhoff 08-28-2004 05:47 PM
Hmmmmm,
How much is a set of Fikses (17 x 8 x 9.5)?
It is a slippery slope!
JonT 08-28-2004 06:22 PM
I think its around 2500-2600 for set of 4 Fikse's in that size at Wheel Enhancement.
anthony 08-28-2004 07:06 PM
How much are the Lindsey wheels? Would it be economical to have them make 16x9s out of two 16x6es?
rattlsnak 08-28-2004 07:36 PM
9s are easy to find, 8s are not, ive been looking for awhile. 8x16 only came on a few years and are much rarer. (aside from the 951 8s)
Lukesportsman 08-29-2004 06:20 AM
Why does no one seem to run 8's all the way around? ST's ran equal rims, correct and they are a great looking car to me. I've asked this before, but never an answer. Why not 951's on front and 911's on rear, or 951's (8's) all the way around on a narrow?
Scooter 08-29-2004 07:18 AM
There should be no problem doing so, but most people probably put 951 8's in front and 9's on the back because they are the widest Fuch possible for each end of the car. 8's on the back would work just fine I'm sure, just not as macho.http://www.pelicanparts.com/support/smileys/2ar15.gif
nostatic 08-29-2004 08:37 AM
wider in the rear helps tame oversteer if I'm not mistaken...
Bill Verburg 08-29-2004 02:50 PM
over/under steer is a dymamic property. A/Xers will want it at their relatively low speeds. For DE at higher speed it is desireable only in very small doses if at all.
Lukesportsman 08-29-2004 05:55 PM
I guess I was thinking about 8 & 8 on a narrow body non SC flared car. Still thinking through options before getting out the plasma and letting the quarters fall to the ground. I as most love the RS look, but my early car is solid.
911pcars 08-29-2004 09:04 PM
Due to fitment issues, I haven't seen 8s on a narrow-bodied car yet, especially Fuchs. If you have, let us know.
The widest I've seen are 15x7 standard or R wheels.
Sherwood
nostatic 08-29-2004 10:01 PM
I'm pretty sure Ingo had 8s on his narrow car. Lot's of negative camber, and a tight fit.
Jack Olsen 08-29-2004 10:53 PM
http://forums.pelicanparts.com/uploa...1079416351.jpg
Both Ingo and David Dorion have done it.
Here's David's thread.
Wil Ferch 08-30-2004 06:55 AM
Luke:
Following your line of (sound) reasoning...I'm running the unusual combo of 7" front ( original rears) on 205/55-16...and 7" rears on 225/50/16, as they came from the factory for rears.
I find this gives my car with stock TB's fine high-speed balance. The stock 6 front / 7 rear under these conditions, with limited slip, and especially on tight corners...was a terrible under-steerer ( required a change in "tactics" of power application to tame properly for low speed turns).
If I put 7" in front, this gave better sidewall support and increased my track in the front...all to cut into excessive understeer. Putting 8 or 9 in the rear...after I put 7 in the front...would likely get me back to the original 6/7 problems that I had. Again...not an insurmountable problem if you go to alternate TB sizes or adjustable sways...but there you are.
Upshot? 951 pattern 8" in the front with either pattern 8" in the rear will likely accomplich the same thing....but you'd be operating at a better-capable point than my 7/7.
another viewpoint......
- - Wil
wanabe911 owner 08-30-2004 08:53 AM
What are these?
What do you think these are, just bought the car? 7's, 8's?
1986 Carrerahttp://forums.pelicanparts.com/uploa...1093884831.jpg
Bob's Flat-Six 08-30-2004 04:16 PM
Alex
Those look like 7's in the rear, So 6's and 7's is what you would have.
If you look at an 8 or 9 x 16 they have a deeper taper to them.
The 6's don't taper in at all from the lip. :)
Trust Me 08-30-2004 04:37 PM
here is 8's in the back
http://forums.pelicanparts.com/uploa...1093912376.jpg
http://forums.pelicanparts.com/uploa...1093912605.jpg
Dave Nordhoff 09-08-2004 04:10 PM
Nostatic, You are correct about about that slope, I'm slipping fast.
After this and all 59 other threads I've read, I think I will go with
Fikse 8 x 17 and 9.5 x 17. I called W-Enhancement today and new
Fuch 9 x 16's are $ 825.00. Ouch! Then I called Greg Fordahl and he convinced me to go with Fikse's for around $2600.00. For all the reasons
mentioned on this board and Greg's advice. Now I have have to decide
which ones. Hmmmmm, FM5's with black centers or all black? My SC is
metalic black. Any fresh pictures out there with black on black?
Dave
ubiquity0 09-08-2004 04:20 PM
I endup up going w/ 7's & 8's. Part of the reason was that allowed me to swap my (virtually new) existing tires (205 & 225 off my 6's & 7's) & save some money that way.
As a result I have a set of 7's & 9's that are gathering dust.
nostatic 09-08-2004 04:22 PM
That seems like a good price...I thought Fikses were more expensive. You going 17s? I'd go with the Mach V in either race black or race satin.
http://www.fikse.com/machv.html
Dave Nordhoff 09-08-2004 04:37 PM
Hmmmm, The Mach V's look really good too! Nostatic you have good taste. Black centers or all black?
