-   -   Corner Balance and Alignment Thread - been awhile since the last one (http://forums.pelicanparts.com/porsche-911-technical-forum/179986-corner-balance-alignment-thread-been-awhile-since-last-one.html)
widebody911 08-28-2004 03:02 PM
This last week I freshened up my suspension with Elephant Racing polybronze bushings, monoballs, and control arm mounts (one of mine was broken!)
I set the ride height to 23 1/4 in the rear, and ended up with almost 1 degree of rake.
Subtracting the 235lbs of ballast, with 1/4 tank and an empty trunk, she's weighing in at a hefty 2438lbs
Here's my corner balance numbers:
http://vintagebus.com/cgi-bin/balance.cgi?name=thom&car=%2777+911+cab&notes=%233 +done&LF=525&RF=480&LR=873&RR=795
I updated the corner balance calculator to give the LF/LR & RF/RR ratios
Here's the alignment settings I'm going to ask for next week:
Front
Toe: 1/64"
Camber: -2.0
Rear:
Toe: 1/32"
Camber: -2.5
MuffinMan 10-13-2004 02:26 PM
Thom,
Was there much a difference in feel going from polyurethane (?) bushings & rubber mounts to polybronze & monoballs? Is there much more NVH (noise, vibration, & harshness) on the street than before the change?
widebody911 10-13-2004 02:39 PM
A little bit more; the NVH difference between HD shocks and Sports was greater than the NVH difference with the monoballs & polybronze bushings.
Jeff Alton 10-13-2004 05:48 PM
I found with the monoballs, the only difference was heard or felt when you hit a "sharp" object like a reflector or a slightly protruding man hole cover or something of that nature. Magical change in steering response and turn in though.
Jeff
