Corner Balance and Alignment Thread - been awhile since the last one
This last week I freshened up my suspension with Elephant Racing polybronze bushings, monoballs, and control arm mounts (one of mine was broken!)
I set the ride height to 23 1/4 in the rear, and ended up with almost 1 degree of rake.
Subtracting the 235lbs of ballast, with 1/4 tank and an empty trunk, she's weighing in at a hefty 2438lbs
Here's my corner balance numbers:
http://vintagebus.com/cgi-bin/balance.cgi?name=thom&car=%2777+911+cab&notes=%233+done&LF=525&RF=480&LR=873&RR=795
I updated the corner balance calculator to give the LF/LR & RF/RR ratios
Here's the alignment settings I'm going to ask for next week:
Front
Toe: 1/64"
Camber: -2.0
Rear:
Toe: 1/32"
Camber: -2.5
Old 08-28-2004, 03:02 PM
MuffinMan's Avatar
Thom,
Was there much a difference in feel going from polyurethane (?) bushings & rubber mounts to polybronze & monoballs? Is there much more NVH (noise, vibration, & harshness) on the street than before the change?
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 10-13-2004, 02:26 PM
A little bit more; the NVH difference between HD shocks and Sports was greater than the NVH difference with the monoballs & polybronze bushings.
Old 10-13-2004, 02:39 PM
Jeff Alton's Avatar
I found with the monoballs, the only difference was heard or felt when you hit a "sharp" object like a reflector or a slightly protruding man hole cover or something of that nature. Magical change in steering response and turn in though.
Jeff
www.turn3autosport.com
Old 10-13-2004, 05:48 PM
