it done blowed up
went to start the car this morning, and BANG! Uh oh...sounds like a CIS backfire. No worries...I've got a popoff valve installed. I try to turn it over...no go. I go back to check and the airbox is askew. I pull the cover and lo and behold, the popoff valve has popped off...completely
I pressfit it back into the hole and the car started right up. So I'm assuming I can just glue it back into place. Any recommendations on what to use for the adhesive? I was figuring a 24hour epoxy would be fine, but am open to the "proper" suggestion. |
I have found that trimming down the ribbed area to flush is the best way. Ive used JB weld in the past with no problems .
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
i used JB Weld, works fine.
Nikita 1977 911s Targa |
Information Junky
An epoxy should work . . .
if you tell me the materials, I can suggest the "proper" adhesive.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
It's a good idea to scuff the glue area of the valve with sandpaper. This give the adhesive some tooth.
Out of the box these things are too smooth, slick even. Glue doesn't like them. Be sure to clean everything thoroughly with a good degreaser too.
Chuck Moreland - elephantracing.com - vonnen.com |
Popping off the Pop-off valve - lucky you. Or wait, maybe the Porsche Gods were trying to get you into a 3.6 swap...
Happy Thanksgiving! Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
same thing happened to me I just reglued it.
Happened to me too. I sanded off the old adhesive and used JB weld to reattach.
JB Weld is your friend.
Get all the old sealant off and give a good cleaning with alcohol to remove oil residue. Then JB it back in by putting a 1/8"bead all the way around the bottom of the pop off valve. That way when push it back in a nice bead will form and seal it up.
Thanks! Don Ramsay E Mail: aircooledclassicsporsche@gmail.com The father of 964 Backdating! www.aircooledclassics.co www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/ |
JB Weld is epoxy. You can use that, or get something in the way of a 5 min, 2-part epoxy and be one your way in 10 minutes. For these kinds of plastics, I like something of the nature of a polyurethane adhesive/caulk. Slow to dry and cure, though. Chuck is right, sanding and cleaning with something like acetone will help immensely.
Todd, when you said "blowed up," and I didn't see you this morn at Gelson's, I thought the worst. Glad it wasn't that.
GOT TURBO..
Grind a groove into the Pop off valve so the epoxy has something to bond with.. Recheck your mixtures before you plan to run it..
Wow, it worked ok. Much easier than (paying for) a new airbox.
I second what chuck said about the sandpaper. |
You may have fixed the pop-off valve from separating from the airbox but what caused it to completely come off instead of opening like it should have to release the pressure? By regluing it so tightly the entire airbox may blow apart next time if the valve isnt working properly and there is no where for the backfire pressure to vent.
1980 911SC Targa 3.6L |
Alii&Maui
Lube the O ring on the pop off valve. I hear the rubber tends to stick.
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
Air Medal or two
3m 5200
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Senior Member
Lots cheaper and easier than the airbox. The pop off valve just paid for itself!
JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
JB is great, generally.. but in such application I would use something like the 5200 extreme. It's a MarineTex product. although the 5200 would also be overkill for the application. 5200 is great and comes in various colors. Anything other than white seems to have a short shelf life in my experience. the sunroof site where I used MarineTex and why. '77 Sunroof Air Deflector Upgrade
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
My pop-off valve came un-glued years ago when I was nowhere near home. The broken glue joint would not permit a leak-free press fit, so I was stuck. An oversized cork finally got me home. From then on I carry an adjustable rubber freeze-out plug in the tool kit, thus insuring that I will never need it.
Howard
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
Unregistered
Todd, I wouldn't use 24 hour epoxy. You will want the glue to last much longer than 24 hours
Sand the area well, glue it back down, and adjust the mixture 1/8 turn clockwise. Life is gud. |
Air Medal or two
the 5200 will remain flexable thrue history and will never let go
