Me like track days
Craig 930 RS's Avatar
Exclamation * Front oil cooler install - UNIQUE? *
Eight 2 3/4" holes in bumper
Front strip removed
Strip area painted black
Keeps the 3.6 Varioram cool and looks reasonably stock!
A bit RSR perhaps?
holes
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 08-23-2004, 08:31 PM
Designer King
Paulporsche's Avatar
Did you drill the holes yourself, or have a machine shop do them? On or off the car?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-23-2004, 08:43 PM
Yellowbird RS's Avatar
cool! but maybe you drill 2 extra holes (bouth end sides)
X/A
Old 08-23-2004, 08:50 PM
Az911's Avatar
Send a message via AIM to Az911
Looks good here is another car with a similar setup.
72T RS look
96 993
Old 08-23-2004, 09:14 PM
jakermc's Avatar
Did you modify the trunk area at all to allow the air to go through the cooler and exit out the back and then down below the car? Don't these things need a good exit path for the air if they are to work properly? I am getting ready to do my own install and am looking for ideas.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 08-24-2004, 05:35 AM
Pix of my oil cooler setup here: http://66.34.72.138/howto/965-bumper/index.html
Old 08-24-2004, 06:16 AM
Craig:
Nice job...I believe the Rothman's Dakar cars did it this way too.
Any more details on the install ??
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-24-2004, 07:00 AM
Designer King
Craig,
Just a thought:
How about if you reattached the rub strip w/ the holes correspondingly drilled in it, and blocking off the 2 outer ones in the body (unless you need them)?
This might give you a less obvious, more finished, factory look.
I realize you may have to drill the holes a little smaller, to keep it all together, which may be a problem on your car's cooling system. Only you can answer that.
It's just something to consider.
Paul
Old 08-24-2004, 08:03 AM
KobaltBlau's Avatar
tell us if you cut the tub!
Andy
Old 08-24-2004, 08:06 AM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
and give us a shot from farther away so we can see the full effect.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 08-24-2004, 09:33 AM
KobaltBlau's Avatar
Thom, nice job on all that. Looks great, too!
Andy
Old 08-24-2004, 09:44 AM
Looks good. What brand and size oil cooler did you use? I have been long interested in doing this. Good solution.
Sean
'77 911S Cab Conversion
Old 08-24-2004, 09:52 AM
Me like track days
I did it myself & used a 2 1/4" hole saw (not 2 3/4" as I posted last night), with WD-40 for lube (it's a hell of a cut!). Bumper off the car -
Used a pneumatic drill. Hang on when making these large holes, it'll rip your wrist off
No exit path other than the 1 1/2" standoff already built in using the upper horizontal mounting tabs on the Setrab cooler. Still not nearly as much backspacing as I'd like - but lets see how this works.
It is not possible to put the cooler out more towrds the front bumper using the Setrab mounts - this, or make an exit box. If I need to do either, I will.
I have two SPAL 4" fans (bought the last 2 in the U.S. directly from SPAL; these are impossible to find)
A note about the pics:
I used a flash - it highlighted the internals. In person, it is very subtle; you cannot tell what is inside & behind the bumper. Also, in person it is hard to tell there are even holes in the bumper!
Here is a pic w/o flash & what it looks actually like:
Any questions - just ask.
Old 08-24-2004, 10:11 AM
Craig:
-- Is the top of the lower valence modified, or is that the lower portion of the cooler itself?
-- as to exit air... I have a strong suspicion that all you need is to close the air gaps on the perimeter of the cooler ( foam padding)...and don't worry about the air space behind the cooler...as long as there is *some* space behind the cooler.
-- the cooler is mounted on the bulkhead, correct? Not on the bumper itself?
-- consider a small mesh...or even a cut-down of a rear deck lid grill to give the holes a "finished" look ?? Heck, if under a grill, the "holes" can be a big rectangle !
---Wil
Wil Ferch
Old 08-24-2004, 01:27 PM
Me like track days
Wil -
Top of lower valence does have about a 1" notch cut in it
Exit air - EXACTLY! I have extra roll bar padding (will it melt, Wil?)
that I was thinking of using
Cooler is on the bulkhead -- the cooler is mounted using the top 2 brackets which attach to the top of the bulkhead where the bulkhead becomes more horizontal
I will add some mesh for cooler protection - the nice thing is the front end has sort of a 'black-hole' appearance so it is hard to tell that anything has been done to begin with.
I went for a test run - big difference! Above 40 mph or so the temps plummet -
THX
Old 08-24-2004, 02:53 PM
Ove Ove is offline
911 driver
Ove's Avatar
Talking
Craig,
Very nice install!
I like that you retain the stock look.
You could place an aluminium plate about 1" to 1.5" down under the bumper to direct even more air to the cooler.
But if it works well now without any problems I would leave it as it is.
And you are saving some weight too by making the vent holes and removing the rubber strip
Ove
'77 911S targa
Old 08-24-2004, 03:43 PM
Me like track days
Ove -
You & Wil seem to read my mind --- I have a sheet of aluminum plate that I intend to use just as you say -
THX
Old 08-24-2004, 03:50 PM
jakermc's Avatar
I'm a bit confused about the suggestions to close off the air gaps around the cooler. With the cooler mounted to the bulkhead, which sides of the cooler should be sealed? Obviously there are two sides, a top and a bottom, 1.5" of space behind the cooler and the air has to exit somewhere. Is the idea to close off some of the sides and force a single exit?
Did the cooler bolt to the bulkhead or was welding required?
What size cooler are you using and where did you buy it from?
2003 Ferrari 575M
Old 08-25-2004, 05:11 AM
The idea is to seal off the entire *perimeter* of the cooler. As air enters, it *has* to go THROUGH the cooler. Otherwise...fluid dynamics being what it is...it will tend to take the path of least resistence, which can be AROUND the cooler instead of through it.
Craig, I don't know if the roll bar padding is the right thing to use ( temp capability), but there should be some sort of edging like used on the factory front Carrera coolers that would work. I'd look at the industrial supply and Aircraft supply places mentioned in these threads.
---Wil
Wil Ferch
Old 08-25-2004, 06:36 AM
That looks great Craig. How much room is behind the cooler? If by chance someone rolls into you and the front shocks compress, will the cooler be in trouble? I ask only because I have similar issue's with my install but ended up notchin the bumper to allow for a little movement. Looks great !
I ended up going with a lower mount into a glass valance below the stock bumper but I do wonder what will happend in the even of a serious off track excursion. This weeekend I did some "grass mowing" after going in too hot in one corner but all was well.
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 08-25-2004, 07:08 PM
