cross member
A while ago a board member posted with some pictures of an early RSR cross member
what is the visual difference between that alloy cross member and one from a normal 911SC??
Old 02-07-2005, 09:02 PM
PRO Motorsports
Tyson Schmidt's Avatar
Looks like there are two bolts holding the strap to the crossmember instead of one.
I bet there is also a difference in height for the perches where the steering rack bolts on. The Turbo's were different here, because the rear of the control arm mounting points are raised in the chassis to build in some anti-dive suspension geometry. I wonder if they did this on the RSR first.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-08-2005, 05:47 PM
bigchillcar's Avatar
Figured this thread was going to be about a pissed-off pelicanite...
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-08-2005, 06:50 PM
Sorry Ryan just looking for information.
I am doing a restoration on a long hood and I keep coming up with funny parts which dont make sense to be on the car.
Micahel
Old 02-08-2005, 06:55 PM
For the record RSR & early 73RS aluminum front crossmembers are a forging not a casting. All the production crossmembers are cast aluminum. You can see the nice smooth finish of the metal in the photo.
Old 02-08-2005, 08:09 PM
So are the shiny ones the forged and the dull ones cast??
Michael
Old 02-08-2005, 08:17 PM
It isn't that simple. I've seen "regular" aluminum ones polished.
The are dimensional differences as described above, and if you looked at the two up close you'd seen a graining diffrerence in the metal itself. I think one other way might be the date stamped into the part. Most RSR & RS's were 73-75. The aluminum production crossmember didn't come into play until somtime around 1978. There is usually a little mark on these with the date of manufature on it.
Old 02-09-2005, 07:01 AM
Well I has a good look at the one that came off my long hood and it is reasonably shing and does not have any date marks. it doesnt look like it been polished.
Michael
Old 02-09-2005, 02:38 PM
Maybe you have an RSR and don't know it??
Old 02-09-2005, 06:41 PM
With this car nothing would suprise me.
When I started to strip it down I was expecting to find some rust. I was pleasantly suprised when no rust was found.
It was when we started looking at the mechanical parts that things got interesting. Like the front cross member the rear trailing arms have been boxed, the fornt apron has holes in it and it is recessed back like it had a 2.7RS oil cooler up there.
THe car is a matching numbers car with full serive history from day one so i would assume it has not been raced but something doesn't add up.
But it will make a great 911ST clone.
Michael
Old 02-09-2005, 06:56 PM
Sounds like you have an interesting project. Post some pictures of your progress with us when you can.
Old 02-09-2005, 07:41 PM
jluetjen's Avatar
What's the number on the car? Who knows, maybe you have an ST?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-10-2005, 03:46 AM
John,
don't have the number with me at work will post on monday.
Michael
Old 02-10-2005, 01:52 PM
