-   -   Any reason to have a chip mode/non-chipped mode? (http://forums.pelicanparts.com/porsche-911-technical-forum/180727-any-reason-have-chip-mode-non-chipped-mode.html)
bigrubberjeep 09-02-2004 09:13 AM
Any reason to have a chip mode/non-chipped mode at the flick of a switch?
I thought I had seen this in the past, just cant find it.
magilla 09-02-2004 09:17 AM
I think the reasoning was for performance on one side, and stock on the other. The stock would be better for fuel economy and for emission inspections.
The one you are referring to is likely the "no bad days" (sp?) chip. I think Ingo and MikeZ might be involved somehow.
BGCarrera32 09-02-2004 09:21 AM
I don't have the luxury of a switch, but I did have a chip burned with a 2800 RPM rev limiter if it ever needs to go to the body shop. Should keep the car in the parking lot...
emcon5 09-02-2004 09:22 AM
Smog checks and fuel quality immediately come to mind.
Tom
bigrubberjeep 09-02-2004 09:26 AM
Is it a good "makes sence" idea for the sake of fule economy, or is it easier just to swap chips for emissions since fuel economy wont bemuch different?
Wil Ferch 09-02-2004 09:50 AM
I've seen this offered for 944's.
A "plug" is insertd into the motherboard and a cable with two receptacles 'hangs out" outside of the box. Something like that. Wouls make chip change-out easy w/o opening th box.
Emissions, etc. as stated would be another influence....
--Wil
BGCarrera32 09-02-2004 10:03 AM
http://frwilk.com/944dme/
Click on dual EEPROM adapter
Jack Olsen 09-02-2004 10:42 AM
I have the NBD chip, with the switch. I only run the performance settng with 94 octane fuel. My concern would be the risk of pinging with poorer fuel, which is all that's available in California. I don't believe there's a two-position chip available for 3.2's, which is a shame, since there's no knock sensor on those motors. In my opinion, NBD and Steve W should get together and make this happen.
Wil Ferch 09-02-2004 10:58 AM
Jack:
The conceptual problem I have with the switch is what do you do when you have a "blend" of fuels ? You typically don't run either case to a "dry" tank condition.
What's really needed is a dynamic system that adjusts automatically, by retarding timing and "X"....when there is imminent pre-detonation...like today's modern cars....going back up when higher octane fuel is sensed.
Wil
bigrubberjeep 09-02-2004 11:00 AM
I am hoping Steve chimes in with some "good news"
tsuter 09-02-2004 03:08 PM
I have an electronic "chipswitch" on my key fob for the VW NB. Three installed programs: Race, Stock, Valet.
Anyone got teen age drivers?? You figure it out.
ChrisBennet 09-02-2004 03:34 PM
The multimap 3.2 chip is "known technology" to Steve W and other the DME hackers on the board.
-Chris
buttjoint 09-02-2004 04:27 PM
I have the steve w chip in my 3.2 and no problem passing emisions.
jazzbass 09-02-2004 07:07 PM
I'm no DME hacker, but it seems like it would be very easy to do, really. The chip for a 3.2 DME is what - a 27C64? Get a 27C128, burn both maps in it, and toggle the A13 line with a buffered switch. Whether on nor you should do it is another question.
ChrisBennet 09-02-2004 07:51 PM
Bingo. You can even have 4 maps with a 27C256. They don't even buffer the switch (which seems a little odd but apparently works).
-Chris
jazzbass 09-02-2004 08:02 PM
-Chris
I personally would be uncomforable with that. For me, I'd wire the switch into the input of a D flip-flop and hook the clock input of the f/f to a R/C delayed rising edge. Capture the switch state at power on and keep it that way until power down. I don't like the idea of maps randomly changing while driving. But that's just me.
kepperly 09-02-2004 08:29 PM
no! in short if you bought a Steve Wong chip, you have a better running car so why would you want to go back.
Keith Epperly 87 turbo look carrera cabriolet opps forgot slant nose!
bigrubberjeep 09-02-2004 09:05 PM
That's the point of my question.
