-   -   Deleting Bumperettes, Move the plate lights where? (http://forums.pelicanparts.com/porsche-911-technical-forum/181170-deleting-bumperettes-move-plate-lights-where.html)
na2ub 09-05-2004 09:45 AM
I would like to delete the huge bumperettes on my 79 Targa, but I am not sure what to do with the license platet lights that are housed in them. I suppose I would need to remount them in the smaller bumperettes or something alike. So for those that have done it, what did you do?
Doug
Glasgow 911SC 09-05-2004 09:55 AM
I believe you can get number plate bolts that double up as (LED) number plate lights. I'll see if I can find where I saw them.
KTL 09-05-2004 09:57 AM
Check out this topic:
Bumper Pad Removal Discussion
EdT82SC 09-05-2004 10:08 AM
Here is an option:
http://forums.pelicanparts.com/porsche-911-technical-forum/178616-license-plate-lighting-option-aftermarket-bumpers.html
na2ub 09-05-2004 10:10 AM
Thanks for the ideas. I am still not really excited about plate bolts that have built in lights. I am not trying to have some sort of fancy bumper, but rather just lose the weight / eyesore of the bumperettes. I was looking for something new to mount them in. Keep 'em comin.
Doug
chrisp 09-05-2004 10:47 AM
http://www.speedwaymotors.com/xq/asp/strBase_List./hilt./source.2192/base_no.91050135/str_base_no.000%2DCATALOG+STREET%2C7209306%2C91004 020%2C91004021%2C910501%2C91050101%2C91050131%2C91 050135%2C91050138%2C91050175%2C91050731%2C91051300 %2C91068000%2C91068001%2C91088200%2C91130102%2C911 30103%2C91661081%2C91662012%2C92539901%2C/header_title.Street+Rod+Products%2DLicense+Plate+F rames/page_name.prod%5Flist%5Fdisplay.asp/search_type.L2%7E304/search_option./deptsearch./deptSearch_id.225/dept_id.L2%7E304/dept_id_p./dept_name./dept_name_p.Street+Rod+Products/ShowImages.yes/sq.0/cont.1/intPgNo.1/redirect./qx/product.htm
http://www.speedwaymotors.com/xq/asp/strBase_List./hilt./source.2192/base_no.91050731/str_base_no.000%2DCATALOG+STREET%2C7209306%2C91004 020%2C91004021%2C910501%2C91050101%2C91050131%2C91 050135%2C91050138%2C91050175%2C91050731%2C91051300 %2C91068000%2C91068001%2C91088200%2C91130102%2C911 30103%2C91661081%2C91662012%2C92539901%2C/header_title.Street+Rod+Products%2DLicense+Plate+F rames/page_name.prod%5Flist%5Fdisplay.asp/search_type.L2%7E304/search_option./deptsearch./deptSearch_id.225/dept_id.L2%7E304/dept_id_p./dept_name./dept_name_p.Street+Rod+Products/ShowImages.yes/sq.0/cont.1/intPgNo.1/redirect./qx/product.htm
http://www.commandelectronics.com/lighting-accessories.html
Randy Webb 09-05-2004 11:07 AM
fit the early deck lid which has built in lights
get some lights mounted in pods and mount them thru the bumper
89911 09-05-2004 01:38 PM
http://forums.pelicanparts.com/uploa...1094416256.jpg
I removed all the rubber on my bumper. Reversed the shock bolts so the studs come out of the bumper. I drilled one small hole behind the plate and used (Lightning Boltz) in place of the license bolts. Works great.
GeorgeK 09-05-2004 01:57 PM
Check eBay. From time to time some gems pop up, like these Hella lights, which were incidentally used on the...917 to light the race numbers ;)
http://forums.pelicanparts.com/uploa...1094417847.jpg
jkarolyi 09-05-2004 05:36 PM
Those are the ones used on my BMW 2002 also. :)
project 911 09-05-2004 07:48 PM
I used some light weight plastic units from a local parts store. They were chrome but I painted them the body color. If I would have known about the LED mounting bolts, I may have gone with those.
http://forums.pelicanparts.com/uploa...1094438811.jpg
Rot 911 09-06-2004 06:37 AM
Originally posted by na2ub
Thanks for the ideas. I am still not really excited about plate bolts that have built in lights. I am not trying to have some sort of fancy bumper, but rather just lose the weight / eyesore of the bumperettes. Doug
Why not the license plate bolts? It is the simplest way to go. They work well and you can even tell they are there unless you have the lights turned on.
http://forums.pelicanparts.com/uploa...1079310212.jpg
89911 09-06-2004 07:47 AM
I'd, of course, agree with Kurt. I frequently get question like "what do you do at nightime?" until I point out that the bolts have lights in them.
http://forums.pelicanparts.com/uploa...1094482048.jpg
na2ub 09-06-2004 08:08 AM
Ok, I am conviced. I guess I will get the lighted bolts or the lighted plate frame. It did not appear that the lighted bolts produced enough light, but if you guys say they are ok, they're ok by me. Thanks for the input. I never knew such a product existed.
Doug
Formerly Steve Wilkinson 09-06-2004 09:54 AM
What is "enough light"? I really don't care how illuminated my rear plate is--I use a plate frame with little built-in bulbs--I just care that I can show the cop, or annual-inspection facility, that yes, the reara license plate is indeed illuminated.
Stephan
na2ub 09-06-2004 10:12 AM
Stephen. Obviously no driver cares if there even is a license plate. The point of the plate and the light is so that the police can keep tabs on you and run your plate when they are behind you. If the fuzz doesn't think your plate is well-lit, it is an excuse to pull you over, give you a ticket, run your driver's license, poke through your car, delay you, and generally big brother you. I (call me crazy) prefer not to give them that excuse. That is why "enough light" is important to me. I don't even have annual inspections where I live, so that is not even an issue.
Doug
na2ub 09-06-2004 10:17 AM
Eastwood Co. is out of stock. Any other sources for lighted bolts?
Doug
Yellowbird RS 09-06-2004 10:34 AM
I'm not the seller:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=35580&item=2488420 454&rd=1
svandamme 09-06-2004 10:35 AM
any details on that tranny mount of yours?
did you make your 911 mid engined? common , share it with the group :D:D
89911 09-06-2004 10:58 AM
It actually is my brothers G50 waiting to install. Mine was at the shop. I gave up on the mid engine idea when I realized I'd be sitting on the valve covers;) As far as finding another vendor, here is one http://www.truckaddons.com/Catalog/subpages/DEI_lightnbolts.htm
If this isn't viable, search the brand on google and find other. Good luck.
