-   -   Where did you run your oil line after installing headers? (http://forums.pelicanparts.com/porsche-911-technical-forum/181188-where-did-you-run-your-oil-line-after-installing-headers.html)
efhughes3 09-05-2004 11:30 AM
I got mine on today, I fired it up with no muffler, sounds great (dog didn't care for it though). My dilemna is running the new oil line. I can tuck it up in the crook of the tranny behind the shifter mechanism, or run it just below same. If I tuck it up, it approaches a kink, but I'd say the line would still pass enough oil...maybe. If I run it down to keep the kink away, clearance COULD me an issue. Where did you put yours?http://forums.pelicanparts.com/uploa...1094408948.jpg http://forums.pelicanparts.com/uploa...1094409012.jpg
911pcars 09-05-2004 11:36 AM
Will the early hard line (U-shaped) retrofit to your setup? It wraps under the engine, around the gearbox/engine joint line.
Sherwood
fireant911 09-05-2004 01:23 PM
That arrangement looks amazing identical to my car when I first aquired my Porsche. The PO had tie-wrapped the line to the clutch arm which looked cheap and ugly. I later removed the entire exhaust system (B&B) because it was incredibly too loud for my (and my neighbor's) taste and replaced it with the factory heat exchangers and muffler. I too am curious on how the braided stainless steel line should be routed and secured underneath the engine so that it looks aesthetically pleasing since I was never able to acheive that objective.
81 930 09-05-2004 02:03 PM
I recently installed B&B headers on my car and found it necessary to backdate my oil line to the pre-1974 style. It clears everything just fine. Did the braided line come with your headers or did you get it from another source?
Here's what my setup looks like:
http://forums.pelicanparts.com/uploa...1094418104.jpg
The line can be purchased from our host for about $69 (C-107-739-10).
Joeaksa 09-05-2004 02:16 PM
Used the pre-74 on my car with the B&B exhaust and it worked beautiful. Also is the same line used when running the SSI system.
JoeA
Bill Verburg 09-05-2004 03:32 PM
I used the early line as the others have mentioned
http://forums.pelicanparts.com/uploa..._008_small.jpg
But to answer your original question. That appears to be the line supplied by B&B w/ for use w/ their headers. Most people run it over the top rather than underneath.
efhughes3 09-05-2004 04:52 PM
Looks like the pre '74 line is the ticket. Thanks!
