Where did you run your oil line after installing headers?
I got mine on today, I fired it up with no muffler, sounds great (dog didn't care for it though). My dilemna is running the new oil line. I can tuck it up in the crook of the tranny behind the shifter mechanism, or run it just below same. If I tuck it up, it approaches a kink, but I'd say the line would still pass enough oil...maybe. If I run it down to keep the kink away, clearance COULD me an issue. Where did you put yours?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Will the early hard line (U-shaped) retrofit to your setup? It wraps under the engine, around the gearbox/engine joint line.
Sherwood |
That arrangement looks amazing identical to my car when I first aquired my Porsche. The PO had tie-wrapped the line to the clutch arm which looked cheap and ugly. I later removed the entire exhaust system (B&B) because it was incredibly too loud for my (and my neighbor's) taste and replaced it with the factory heat exchangers and muffler. I too am curious on how the braided stainless steel line should be routed and secured underneath the engine so that it looks aesthetically pleasing since I was never able to acheive that objective.
Daryl G. 1981 911 SC - sold 06/29/12 |
I recently installed B&B headers on my car and found it necessary to backdate my oil line to the pre-1974 style. It clears everything just fine. Did the braided line come with your headers or did you get it from another source?
Here's what my setup looks like: ![]() The line can be purchased from our host for about $69 (C-107-739-10).
Brian 1981 930 |
Senior Member
Used the pre-74 on my car with the B&B exhaust and it worked beautiful. Also is the same line used when running the SSI system.
JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I used the early line as the others have mentioned
But to answer your original question. That appears to be the line supplied by B&B w/ for use w/ their headers. Most people run it over the top rather than underneath.
Looks like the pre '74 line is the ticket. Thanks!
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 Last edited by efhughes3; 09-05-2004 at 05:57 PM.. |
