Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Front end adjuster question
Now that the ride height is where I want it on the 912-6, the front end has a good clunk when I go over a bump. I've tracked it down to the front end ajusters. With the front end raised, the adjusters don't touch the stops, so when I go over a bump the adjuster is bouncing into the stop.
I've got hard bushings and stiffer torsion bars (21's I think) and Bilstein shocks.
Anyone think this will be an issue? Should I loctite or lock nut the adjuster in place, maybe safety wire it?
TIA,
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 09-28-2004, 06:08 AM
I'm not sure I'm envisioning what you're saying, but perhaps you need to re-index the adjuster so that it makes contact ...even when "unloaded".
Anyone?
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-28-2004, 06:47 AM
Friend of Warren
Sounds to me, like Wil is saying, that your adjusters aren't adjusting anything. I think you should reindex your torsion bars to drop the car down so you can actually use the adjusters.
Kurt V
Old 09-28-2004, 06:53 AM
Stahlwerks.com
jhelgesen's Avatar
But if I re-index the front end adjuster so it touches while unloaded, it would in effect change position when loaded and raise the front end.
Maybe what I need is a backlash spring between the cap and the cross member to keep tension on it when unloaded.
John Helgesen
Old 09-28-2004, 06:55 AM
Stahlwerks.com
jhelgesen's Avatar
So does anyone have a diagram or picture of where the cap should be at zero load? I think I started at horizontal when I installed the new torsion bars.
John Helgesen
Old 09-28-2004, 06:58 AM
I think you can support the A-arms and find another point where the adjuster makes contact. Once ( and If !) you do...try to duplicate that setting on the other side as precisely as you can...so the pre-load and ride height have a chance of being the same.....
Wil
Wil Ferch
Old 09-28-2004, 07:22 AM
