Somewhere in the Midwest
MotoSook's Avatar
Exhaust Barrel Nuts 4 Thin Flange Heat Exchangers
OK Gang. I've been looking for the last hour for a reference/thread (yes, I know how to use the search button ) to the long barrel nuts that one might use with thin flanged SSI's or early heat exchangers when installing them to an engine that had the thick flange HE's.
I recall there was a thread where someone (I think it was Brad something) posted a link to a supplier that sold the deep barrel nuts.
I printed out the catalog page for those nuts, and I have no idea where I put it, probably in with the thousand or so stuff I print out for later reference (but can never find again!).
HELP!
Old 09-26-2004, 06:50 PM
Pelican should sell them... they also have the copper plated nuts.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-26-2004, 07:01 PM
MotoSook's Avatar
The barels nuts Pelican has are for stock installs..
the ones I'm talking about look like these, but they are longer... to make up for reduced flange thickness..
Or do I need to search the Pelican catalog again?
Old 09-26-2004, 07:09 PM
Send a message via AIM to fintstone
Probably looking for Brad Roberts of SSI. He posts a lot on the 914 pages. He is a wealth of info...try a pm.
Stoney
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-26-2004, 10:19 PM
I searched around McMaster-Carr, pelican, etc. and did Not find long barrel nuts.
I use SS M8/13mm and a cheap filed 1/4in socket. Maybe the 12mm box copper nuts with a deep flex socket. KTL/ Kevin posted that the copper is soft so I guess it's somewhat full copper. I have a bunch if you want me to experiment.
The routine seems to be a stack of washers if you want to use the short barrel nuts.. party hearty.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-27-2004, 12:07 AM
Irrationally exuberant
ChrisBennet's Avatar
The nut you want is called a "coupling nut". I looked on MSC and found some. Metric Coupling Nuts
Just go to MSC, McMasterCarr, etc and do a search on coupling nuts.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-27-2004, 01:53 AM
Ray 911s's Avatar
Coupling nuts are threaded all the way through. You would also have to change your exhaust studs to use these - the stockers are not completely threaded.
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 09-27-2004, 04:44 AM
Coupling nuts would be hard to install in place of the barrel nuts but I don't see how they would require different studs.
If you can't find these long barrel nuts, take some normal ones, drill out the threads and then weld them to coupling nuts.
-Chris
Old 09-27-2004, 06:44 AM
Coupling nuts are not a usable substitute; the have no internal wrenching feature and there is not room to get a socket into the heat exchanger access tubes. One would have to resort to the "SSI bent wrench" method (if this is even possible) for all the studs that are accessed through the tubes. Neither coupling nuts nor a taller barrel nut will work if there is not adequate thread length on the lower end of the stud. One may have to make a spacer bushing or use a stack of washers. Jim
Old 09-27-2004, 06:57 AM
Somatic Negative Optimist
Gunter's Avatar
Jim said it.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-27-2004, 07:50 AM
Why not replace the studs? Afraid. Maybe for good reason.
I was in the opposite situation, thin flange and long studs. This was from the PO. They stacked washers. I was fortunate enought to be able to buy SSI w/thick flanges. I did however replace at least a few studs. One problem was that some of the previous studs had no threads near the base of the thin flange so there was no option except replace or use washers.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 09-27-2004, 08:20 AM
Formerly bb80sc
Vipergrün's Avatar
Souk, the "Brad" is here Use the coupling nuts, they work great!
Caveat, I did have to bend a wrench to get these to work. Big deal.....
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 09-27-2004, 08:43 AM
Information Junky
island911's Avatar
2nd
Old 09-27-2004, 08:49 AM
Randy Webb's Avatar
It shouldn't be too hard to remove the studs. If too fearful of snapping one, then I would use grease or glue to stick the washer stack or bushing to the regular nut.
But first I would call or fax SSI - it would be great if a longer nut was made.
Old 09-27-2004, 09:57 AM
Hilbilly Deluxe
emcon5's Avatar
3rd. I used some SAE nuts slightly larger than the studs as spacers, with the stock barrel nuts. Hose everything down with anti-sieze, and it is a piece of cake to swap it out every 2 years.
Tom
82 911SC Coupe
GTI Cup #43
Old 09-27-2004, 10:10 AM
MotoSook's Avatar
O.K! So spacers is the way to go. No problem, I can machine a set easy enough.
Just one thought, why doesn't everyone replace their studs with stainless studs, or something new when they have their headers off? Esp. the guys that have their engine on a stand.....
Old 09-27-2004, 10:53 AM
I've been using stainless for automotive since '66.. in lew of that i personally feel that there is an acceptable place for SS and an
un-acceptable place. As an exhaust stud is ng imo. As a nut on the stud IF using proper technique and maintence it's perfect.
fwiw, I use nickel anti-seize. I think I can send 2oz for 2 stamps in an envelope..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-27-2004, 11:01 AM
MotoSook's Avatar
Thanks for the offer Ron. I think I have some in the garage.
OK..so why is a stainless steel stud not suitable for an exhaust stud?
Old 09-27-2004, 11:05 AM
it'll loosen without lock tite.. and I wouldn't trust lock tite to hold them for the long term. and it's really not necessary to take a chance if new studs are never seize maintained.. besides the heat expansion sucks, I believe.
I bet Jim Sims could give you a better answer, either a yes or no.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-27-2004, 11:10 AM
MotoSook's Avatar
I figured it would have to do something with the different expansion coefficients. Makes sense to me. I could have sworn that there was someone using ss studs or maybe it was just the nuts...
So now someone tell me about the metallurgy of the stock studs
Old 09-27-2004, 11:18 AM
