3.2 CAB's Avatar
Question Carrera Tensioner Replacement
It seems like I might have a right side tensioner going bad. There is not really any odd noises at low idle, but if idle is increased, it sounds like the chain is dragging or hitting something. Sorta like pulling a chain over the lip of a can, the sound increases with engine speed, with a stethoscope, the noise is really strong in the right chain case cover, the left side, just has the whirring sound, nothing odd. This started yesterday while I was at my mail box, and when I got ready to move, I heard the noise, when I increased the engine speed to move. I have only driven it 60 miles since replacing the oil pressure sender, and having to take all the crap off to do that, now it looks like I will have to take it all back off again to check the tensioners.
A few questions now:
1. if you replace one side, should you not go ahead and do both?
2. what about the chains, do they need replacing?
3. does anyone have a parts list of all the required parts, gaskets, crush washers, ramps, guards etc. and any other associated parts needed to replace the tensioners?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-02-2004, 07:06 AM
3.2 CAB's Avatar
I forgot to ask, is it usually obvious to see that the tensioner is bad once the covers are off? Thanks.
Newest additions-
others...
Old 09-02-2004, 07:08 AM
No, it is not usually obvious to tell a bad tesnsioner if it is the normal mode of failure, weakness by aging. If it is a catastrophy like the pin is broken off or something then it is obvious.
How old are they?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-02-2004, 07:13 AM
3.2 CAB's Avatar
Origional equipement as far as I know, and about 60,000 miles.
Newest additions-
others...
Old 09-02-2004, 07:16 AM
It was obvious on mine. You could push the pin down on the broken one with light finger pressure. The good side took considerable pressure to push down. But the sounds yours made is the exact opposite mine did. The chain would make noise at low rpm and then become normal at higher rpm's.
Old 09-02-2004, 07:25 AM
3.2 CAB's Avatar
Maybe it is a guard or ramp broken? I will find out I guess when I take the covers off. Before I start, I do want to have all the parts located though.
Newest additions-
others...
Old 09-02-2004, 07:29 AM
Re: Carrera Tensioner Replacement
should be fine with only 60k mi. There is a method of testing the chain and sprocket by wraping the chain over the sprocket and seeing how much slack is present from lifting the chain from the sprocket. There was a good posting on this awhile ago.. anyway if the chain sits somewhat tight I would be relaxed about the issue.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-05-2004, 11:56 PM
