hkspwrsche's Avatar
Torsion bar splines 40/44 formula?
It there a formula for the amount of lowering you will get for one spline diff on the outer compared to one on the inner. For incremental changes is there a recommended difference? one down(lower) inner and two up(higher ride) on the outer for the fractional changes in ride height?
thanks,
Harold
Old 10-13-2004, 10:38 AM
I would rather be driving
jpnovak's Avatar
9 deg change in spring plate for the outer splines.
8 deg 10 sec on the inner spine
50 sec difference between them should result in about 1mm change in ride height at hub.
Old 10-13-2004, 10:44 AM
I think you mean "minutes"...60 "minutes" to one "degree"
The one up/ one down difference of 50 minutes has been quoted as being something like 7-9 mm ride height difference.....not 1.
Right?
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-13-2004, 02:11 PM
jpnovak's Avatar
OOPs. Yep, calculator gives 7mm ride height assuming about 20" arc length.
Old 10-13-2004, 02:16 PM
Arc is 18.5".....yer talkin to the spring-plate-angle calculator guy...
http://tech.rennlist.com/911/pdf/settings.pdf
Wil
Wil Ferch
Old 10-13-2004, 02:21 PM
jpnovak's Avatar
I know who did all that math. Thanks a bunch. It has been helpful many times. I just guessed at the arc-length.
Old 10-13-2004, 02:48 PM
just playin'.....
Wil
Wil Ferch
Old 10-14-2004, 06:03 AM
