pressure testing oil lines
I've fabricated some new oil lines for an auxilary oil cooler on my 993. I'm using Earl's perform-o-flex and swivel hose ends. I was wondering what is the best way to pressure test the hose/end connections before I plumb the coolers?
Thanks.
Old 09-07-2004, 07:22 AM
Re: pressure testing oil lines
Thanks.
follow directions to confirm the hose is seated into the fitting.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-07-2004, 12:02 PM
david.avery's Avatar
I think aircraft spruce has a kit for a "bubble test", which involves two plugs, one with a bicycle-style valve, into which you put no more than 10 lbs of air. You dunk it underwater, and look for bubbles.
I've never had a fabbed line leak, and my spyder is covered with 'em, and I've done three oil cooler setups in the last 10 years. What I have had leak was stainless flared junctions as the stainless is too hard to conform to the aluminum AN fittings.
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 09-07-2004, 12:37 PM
Re: Re: pressure testing oil lines
per the directions, confirmation is completed by pressure test. . .
Old 09-07-2004, 05:46 PM
