cantdrv55's Avatar
towing a rear wheel drive car - front or rear wheels up?
A friend who just bought a beater 912 for its motor/tranny needed to have the car towed to his home. The tow truck driver had it on the dolly with the front wheels up. My friend argued that the drive wheels should be on the dolly so the rears should be strapped down. The driver said it shouldn't make a diff if the tranny is in neutral but my buddy was finally able to persuade him to take the car off and pull the rear up on the dolly.
When I had my SC towed last year, the tow truck driver asked me if the car was front or rear wheel drive so it mattered to him which wheels he can drag. I'm looking for a definitive answer to this. Of course, a flat bed is the way to go.
Old 09-07-2004, 12:11 AM
Fuchs w h o r e
Your friend's fears on the 912 are completely unfounded. It matters not one bit which end is off the ground. In fact, if you are towing long distances, do not tow the car backwards, you will prematurely wear out the front tires.
Old 09-07-2004, 01:51 AM
Gon fix it with me hammer
svandamme's Avatar
i don't see how having the front end used to tow makes sense
usually the front end is way lower than the rear end, so you have more risk of scraping something
then there's the steering rack, how do you lock it? with the normal steering lock? that wasn't designed to keep the wheels locked during towing, it was theft protection... that's stress to your steering rack... no thanks
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-07-2004, 06:05 AM
vash's Avatar
and if the steering lock let go, you will be wonder who that idiot trying to pass you on the wrong side will be. that would be a scary site indeed. front wheels on the dolly please.
poof! gone
Old 09-07-2004, 06:49 AM
KobaltBlau's Avatar
well said vash
Andy
Old 09-07-2004, 08:20 AM
Bandwidth AbUser
Jim Richards's Avatar
I can't see any other than a flat bed for towing.
Jim R.
Old 09-07-2004, 09:14 AM
nostatic's Avatar
yup...call another tow truck. When mine had to be towed, I turned away the first one that showed up and got back on the phone telling them to send a flatbed.
Old 09-07-2004, 09:34 AM
SC-targa's Avatar
I believe that for long tows, it makes a difference. Most trannys are lubricated by the spinning of the input shaft, not the output shaft. My brother routinely flat tows a vehicle long distances behind his motor home. He has a electric pump to circulate the tranny fluid in his towed vehicle.
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 09-07-2004, 03:40 PM
Not P-car related.....but if you tow an auto-tranny you better disconnect the driveshaft. A friend towed a Pathfinder crosscountry and learned this lesson the hard way......fried the transmission.
64 356C Cabriolet
85 Carrera Coupe...Walker-maintained...Wong-chipped
02 Yukon XL 2500
82 Vespa P200E
186,000 MPS.....not just a good idea....its the Law!
"Too much of everything is just enough"
Old 09-07-2004, 05:22 PM
Bland
unclebilly's Avatar
Depends on the car. Why not dolly it tho, just to be safe, most wreckers have the dollies on the rig and they only take a few minutes to pop under the tires.
I do know that S-10 trucks with the T-5 tranny can't be towed with the back wheels on the ground.
Old 09-07-2004, 05:59 PM
brittbolen's Avatar
Flat bed. I waited 4 hours for one on saturday... AAA pays for it...
B
Old 09-07-2004, 06:09 PM
vash's Avatar
nice points! maybe in neutral, it would be good for short distances only, i know in a jeep, this is the case. even with the tranny and transfer case in neutral, you get tranny damage.
poof! gone
Old 09-07-2004, 07:55 PM
