concentric's Avatar
Mounting a 28 row brass cooler
I just got my 28 row brass cooler in the mail and am itching to get it hooked up to my car. Does anyone know a part number for the brackets that allow mounting of this particular cooler? I checked the Pelican site, but didn't see them listed. Even a picture would be nice.
Thanks!
Jason
Stuff of marginal consequence:
- 1974 911"Carerra" sunroof coupe
Old 09-10-2004, 09:07 AM
Crotchety Old Bastard
RarlyL8's Avatar
I have one of these coolers on my SC. The mounting points appear to be the same as for a Carrera cooler. I can look for you this evening if no one chimes in with exact information.
Old 09-10-2004, 09:59 AM
Designer King
Paulporsche's Avatar
see yesterday's thread by pkfrdh "Anyone recognize this style cooler..."
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-10-2004, 10:05 AM
concentric's Avatar
Thanks guys...
I missed that thread, it gave me just what I needed.
Jason
Old 09-10-2004, 10:21 AM
Senior Member
Jdub's Avatar
From John Walker:
louvre plate 930 207 319 13
lower cover 930 207 121 00
rope seal 930 207 353 00
lower brkt 911 501 490 01
upper brkt 930 207 927 00
3 rubber mts 930 207 239 01
not included are misc screws and clips.
the headlight tab bolts to the bucket, and the lower piece needs to be welded. jw
'78 Targa in Minerva Blue
Old 09-10-2004, 10:23 AM
concentric's Avatar
Originally posted by Jdub
From John Walker:
Do you need the louver plate, lower cover and rope seal for the 28 row? I'm very skeptical about that as this looks like the parts list for a Carerra cooler.
If true, everything else should be the same though.
Be prepared for sticker shock on the brackets.
Jason
Old 09-10-2004, 11:05 AM
Senior Member
Jdub's Avatar
I'd guess the cover plates are for the carrera, but if it works for the goose it'll work for the gander, which is to say maybe we ought to be putting these on the earlier coolers?
In all events, John's list does apply to the Carrera radiator-style cooler so take that advice.
I'd rather fab. my own brackets. This can be done cheaply. If you are inventive enough you might be able to use the existing trombone cooler 13mm bolt hole to anchor things. I dunno. Will be going there shortly enough though so interested in seeing how you make out.
John
John
Old 09-10-2004, 11:15 AM
