Make Bruins Great Again
Painting Aluminum
I'm wanting to paint an aluminum dead pedal black. After I use a self-etching primer, what paint do you recommend so that it won't wear off quickly? A friend of mine suggested spray can epoxy paint. Any idea where I can find that?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
You can find it in a can at most decent home improvement stores. It's also called appliance paint (it's an epoxy). Although, I haven’t seen it in any color other than beige.
Also, consider brake caliper paint. Very tough/durable.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
OK, that's a new option. Any special prep ideas or just self-etching primer?
Many calipers are Al. I'd follow the instructions on the can. I would rough up the dead pedal with some sand paper first if its smooth and reflective.
AllI can add is use the darkest color primer you can find if your top coat is black. Why not powder coat it?
Powder coating should be pretty durable. They can also hard anodize aluminum in black or brown which has a tougher film surface than red, yellow, green, etc.
Sherwood |
Now in 993 land ...
I'd have it anodized at a local machineshop. Short of that, make sure you roughen the surface before painting. Fine sand paper or some bead blasting. (careful it won't deform from the blasting). Increased surface area and some mechanical interlocking will improve adhesion of the paint.
George |
Slumlord
Go to an aircraft shop. They will have everything you need.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Yeah, paint it with Randolph's Wing Walk compound.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Good ideas. I wonder if brake caliper paint will work. I need something that will hold up to contact (not just heat). What do you think some of these things will cost? I am not looking to spend $100 on a dead pedal since I can buy one in black for $50. I have a can of self-etching primer but it is in grey. Do you think this will be a problem?
Now in 993 land ...
Joe:
Don't sweat it. Sandpaper, primer and a good can of semi gloss spray paint. Worst thing that can happen is that you have to repaint it in a few years. George |
Just a thought, but you could paint it black and then add some black griptape, like is used on skateboards, to the top, it's ultra durable, and gives a slight "performance" gain in that there's more traction on the dead pedal. Then you could use just about any paint b/c you won't really be in contact with it.
klaucke-that is an awesome idea!
