86 911's Avatar
Send a message via AIM to 86 911
1986 Porsche 911 headlight
Hi everyone,
I am new to this forum. I have recently purchased a 1986 Porsche 911 Cabriolet, and I am having headlight problems. When I turn the lights on, the passengers side light is dimmer than the drivers side light. I have gone to Napa Auto parts, purchased 2 new Hella H4 bulbs and installed them, but the passengers light is still dimmer than the drivers side light! Both lights look extremely clean.
Here is some background info on the car:
1986 cabriolet body w/ turbo look and BBS rims
1976 911 frame
1978 ? Porsche 911 SC 3.0 engine (engine # 930/04)
targa conversion to cabriolet
Also ,the owner that had the car before the owner that I bought the car from had the 3.0 engine rebuilt, and it currently has 40 K miles on it. Which year is the engine number 930/04 from? I am assuming 1978 or 1979, but I am not sure. A photo of the car is attached.
Thank you,
all help will be appreciated,
Matt
Old 09-04-2004, 11:29 PM
zbph10's Avatar
For the headlight issue find someone that has a voltmeter and check the voltage going to the bulb sockets.
If they are the same your problem could be the bulb/lens/reflector.
If they are different check for loose or corroded wires/sockets/connections/high resistance grounds.
Engine information
930/04 78-79 USA SC 180HP@5500 8.5:1 39mm Ports
Nice looking car, enjoy it.
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 09-04-2004, 11:55 PM
djmcmath's Avatar
Congrats on the new car, and welcome to the board!
Something else you might check, while you're looking at headlights, is the headlight relay kit. It's a pair of relays that you wire into the fuse box to remove most of the electrical loading out to a set of relays that can actually handle the load.
Have you swapped lenses, reflectors, or bulbs, from one side to the other? That might give some more indication...?
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 09-05-2004, 08:13 AM
What happens if you hit the high beams?
Old 09-05-2004, 09:34 AM
86 911's Avatar
Thank you for all the responses!
If I turn on the high beam, the passengers light is still dimmer than the drivers side. I have not swapped lenses, reflectors, or bulbs from one side to the other. I am about to go in the garage and take a look at the fuse box and check the relays for the headlights, and do what djmcmath and zbph10 suggested in the previous posts.
Matt
Old 09-05-2004, 11:19 AM
911mot's Avatar
Locate the earth terminal in the headlamp multiplug and run a fly lead from it to the battery negative pole.
If the headlamp is now bright you have an earth problem.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 09-05-2004, 03:00 PM
86 911's Avatar
When I looked at the fuse box, I saw that fuse #5 is missing the upper wire. This may be the problem. I also looked under the light switch in the car and I found that the wires were taped with electritians tape. I will check the ground later and see how many volts both headlights currently have.
Thanks,
Matt
Old 09-05-2004, 03:45 PM
djmcmath's Avatar
Ooh. Electician's Nightmare. It could be a long dark road ahead, full of gooey masses of electrical tape wrapped tightly around crudely spliced masses of wiring, trying to track down one intermittent electrical signal.
(ahem) But I'm sure you'll have those headlights up in no time.
Dan
Old 09-05-2004, 03:53 PM
Make Bruins Great Again
Por_sha911's Avatar
This may be a dumb question but did you check the alignment to see if the dimmer light is aimed lower? Check out the relays and check your wiring.
Joe
Old 09-05-2004, 04:51 PM
86 911's Avatar
Joe, "did you check the alignment to see if the dimmer light is aimed lower?". This is not a dumb question at all. In fact I have not taken off the headlight to check anything yet, so I do not know about the alignment.
Dan, I wish that I could share a smile with you at this moment!
911mot, I have not checked the ground wire yet to see if it is the fault in this situation yet.
Brian, the bulb and lens reflector looked in very good shape when I added new bulbs a week ago.
So far what I have done today is check the fuse box (with the help of my Haynes manual), and tried to switch the high beam and low beam fuses (fuse #5 and #6), but I had no luck in identifying if the problem is in the fuses since the car is not original and has been rebuilt, so the fuses are different than stated in the book. Tomorrow, I will call my friend who knows a lot about electrics, and hopefully I can bring the car down to his place, and he can take a look at the configuration. If not, then I will spend a few hours tracing wires from the headlight to the fuses, remove the fuse box to get a good look at the wires, and then I will know which wires are causing the problem.
Also, does anyone know if the lens of the headlight act as a ground?
Matt
Old 09-05-2004, 10:58 PM
the lens should be glass. The headlight frame is not used as a ground. The ground should be the tub.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-05-2004, 11:06 PM
Irrationally exuberant
ChrisBennet's Avatar
Re: 1986 Porsche 911 headlight
1976 911 frame
Where your car has a mix of years make sure you include the year of the associated system (electrical, brakes, transmission, suspension) so we aren't scratching our heads looking at an '86 wiring diagram when you have a '76 wiring harness or vica versa.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-06-2004, 08:18 PM
Designer King
Paulporsche's Avatar
Welcome.
I had this problem some time ago. I think one of the screws holding the housing into the bucket was loose. When I tightened it, it must have made a better ground and the lamp returned to its normal brightness.
Sorry I can't give you a better explanation. I wasn't even sure @ the time what it was...it just worked.
Let us know what works.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-06-2004, 08:38 PM
86 911's Avatar
I am not sure what year the transmission or wiring is from, but I think it is from a 1976. I did not have much time to get anything done today, but what maybe the problem is that fuse #5 is missing the upper wire as well as another fuse further up the box. Paul, tomorrow I will try to tighten the screws that hold the housing into the bucket as you suggested.
Thanks,
Matt
Old 09-06-2004, 09:00 PM
Designer King
Try pushing on , twisting, tightening, cleaning etc anything that might complete a ground.
Paul
Old 09-06-2004, 09:04 PM
Registered abUser
TerryH's Avatar
The 930/04 is 49 state compliant. That's not great if you live in CA. It must of been smogged to change owners, so maybe there aren't any issues to worry about.
'81 911SC Coupe SOLD
Old 09-06-2004, 09:06 PM
86 911's Avatar
Terry, I hope there won't be any issues to worry about with smogging, and the new California law that is bieng taken in consideration.
Paul, I will tell you what I find out tomorrow. I think there may be something wrong with the ground as you suggested. I am going to bed now and I will try to post more tomorrow afternoon,
Matt
Old 09-06-2004, 09:28 PM
From the "other" post you have going on currently...it is apparent that you have a 76 car...not an 86 as you guessed. hope you didn't overspend to get this car.
As such, look at 76 wiring set ups. I notice that the fog lights in your original picture are of the 78-83 3.0 body style variety....and not of the 84-89 Carrera variety...lending more credence to your car being a mid 70's vintage. Check VIN's to make sure.....
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-07-2004, 08:18 AM
86 911's Avatar
Wil,
The car's VIN number is from a 1976, although when advertised, the seller said the car has a 1986 cabriolet body with the turbo look, a 3.0 engine and a 1976 911 frame. I paid $13K for the car. It looks great except for a few paint blistes and scratches and runs great. What will it take to upgrade my 79' 3.0 engine for it to gain about 40 H.P and look like a 1986?
Matt
Old 09-07-2004, 04:39 PM
The only visual clue as to an 86 ( turbo-look cab)...would be the updated front lower valence that has the fog lights more integrated than what you have. Off the top of my head, I can't think of any other visual clues.
40 extra hp? Tough......maybe SSI's and a sport muffler..that would get you about 17-20....the remaining 20 will be tough.
Wil
Wil Ferch
Old 09-08-2004, 05:41 AM
