MAGA
Tim Hancock's Avatar
DIY Distributor Repair
One of many problems I have had to address after acquiring my "cheap" 1979 SC is that my distributor had some issues.
-Excessive axial and radial play (1/8" axial, 1/16" radial)
-Vacuum advance frozen
-Mechanical advance questionable
Here is what I did:
-Grind off one side of exposed pin on drive gear then punch out.
-Remove all screws from perimeter of distributor body.
-Remove three allen head screws that retain winding assy from
top (these are difficult to see).
-Carefully rock vacuum assy to free it up and then remove
-Pull entire shaft assy out of distributor body.
-Clean everything
-Free up sticking advance weights with penetrating oil
-Free up vacuum advance plate(it is supposed to rotate freely
back and forth about 5 degrees or so).
-Knock out old top bearing (appeared to be sintered metal)
-Replace bearing with oilite bronze bearing (I had to custom
machine one on a lathe to fit). The shoulder thickness on the
needs to be such that there is only a few thousanths of axial
play when assembled (I suppose shims could be used if you
could find some).
-Reassemble
Before
After
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 09-10-2004, 05:43 AM
konish's Avatar
Tim,
Very cool. I cleaned my dist as well as it was starting to howl...and here I was using belt dressing thinking it was a squealing belt. My top bearing was good, so I left it in. As for shimming, I could not find any that would fit the shaft between the drive gear and the shaft housing. Although barbaric I used some morosso chevy 1/2" dist shaft shims to replace the roasted ones from my dist...
R/
Dustin
Old 09-10-2004, 05:52 AM
Designer King
Paulporsche's Avatar
Good job and pix, Tim. What did you do/use for lubrication?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-10-2004, 06:25 AM
JK-81SC's Avatar
Very nice work. Your "before" picture looks like the distributor went through a fire. I used 3 in 1 oil on my dist when I did a rebuild. I was lucky and didn't have to replace bearings on mine, but it was still a gunked-up frozen mess inside.
Thanks for the pictures.
Jeff
1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift
1998 F-150 4x4 - Snow Time
1998 Yamaha WR400 - Mountain Ride
Old 09-10-2004, 06:58 AM
MAGA
I lightly greased the internal moving parts and used nothing on the oil- light bronze bearing. I am assuming the oil impregnated in the bearing will suffice. Does anyone have any other suggestions? The whole assembly was dry when I took it apart. The upper bearing was totally shot and the shaft thrust surface was wearing away at the base of the distributor body.
I intend to occasionally (once a year or so) spray a light shot of spray grease thru the inspection window to keep this from happening again.
0% Liberal
Old 09-10-2004, 07:17 AM
Very nice. I'm about to replace the internal belt on a 993 distributor, and was just wondering where you got a new drive gear retaining pin for yours.
Old 09-10-2004, 08:16 AM
MAGA
Colin, I have not pinned it yet. I will make a mild steel pin slightly long then peen the ends over to retain it. I have heard of others using roll pins.
0% Liberal
Old 09-10-2004, 08:51 AM
Thanks Tim.
Old 09-10-2004, 08:54 AM
I would rather be driving
jpnovak's Avatar
I would also suggest pulling the clips, sliding off the magnetic rotor assembly, then the coil windings. This will get you down to the advance plate. Then remove the E clips and clean/lube the advance weight plates and posts. If they were that rusty and frozen they need the crud cleaned out. Ask me how I know.
Great job on the oillite bearing.
Old 09-10-2004, 08:56 AM
C-2 and others, distributor pin 930 602 922 00
206 637 4071
Old 09-10-2004, 10:39 AM
Senior Member
Jdub's Avatar
Fun job and very worthwhile. I used a fairly viscous oil to lube the plates and whatnot
Were you able to save the plastic sheathes that sit over the pins on the advance mechanism plate? These protectors often rot away and most folks don't know to replace them.
I used a section of chain link as my replacement pin. Not a stressed member.
For those contemplating this task it is well worth the time since your car depends on a smooth advance curve. Be careful to remove all swarf from drilling that pin so that nothing gets between the pinion gear and shaft. I had a bear of a time getting one tiny piece out so that the pinion would slide off easily.
John
'78 Targa in Minerva Blue
Old 09-10-2004, 11:10 AM
MAGA
My advance pins were fine although the lighter spring mnt tang was bent so that this little spring did nothing until the last litle bit of travel (the plastic bushing/sleeves where the spring attaches were fine). I decided this was how it came as there is nothing that could have bent it in there. I did not want to mess with the factory advance settings.
After grinding off one peened end of the drive gear pin I was able to drive it out with a punch.
0% Liberal
Old 09-10-2004, 12:30 PM
