-   -   headlight connectors, I need a source (http://forums.pelicanparts.com/porsche-911-technical-forum/182134-headlight-connectors-i-need-source.html)
jpnovak 09-11-2004 04:22 PM
I am down to the last connections for wiring up the lights for the ST project. Lets just say that every wiring harness was cut instead of nicely pulling the plugs and fishing wires. So, the headlight connectors were cut before I got the car. I need a source for the oversized crimp connectors for H4s. They are not 1/4" faston type. They are indeed wider.
jpachard 09-11-2004 04:51 PM
Jamie, I was able to purchase the whole connector with flying leads at my local auto parts store. I used to live in Austin, try the Auto Zone on South Lamar South of Barton Springs.
Cheers, James
fintstone 09-11-2004 04:55 PM
Not sure which part you need...is this it?
http://www.eagleday.com/heco.html
jpnovak 09-11-2004 07:58 PM
Thanks for the sources. Those are exactly the parts I need.
James, I will check AZ tomorrow, Its close to the house and a block from the 7-11. Slurpees keep me going through the hot days around here!
RoninLB 09-11-2004 11:44 PM
I use Bosch high watt bulb connectors that has screws to attach the wires.
