I would rather be driving
jpnovak's Avatar
headlight connectors, I need a source
I am down to the last connections for wiring up the lights for the ST project. Lets just say that every wiring harness was cut instead of nicely pulling the plugs and fishing wires. So, the headlight connectors were cut before I got the car. I need a source for the oversized crimp connectors for H4s. They are not 1/4" faston type. They are indeed wider.
Old 09-11-2004, 04:22 PM
Jamie, I was able to purchase the whole connector with flying leads at my local auto parts store. I used to live in Austin, try the Auto Zone on South Lamar South of Barton Springs.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 09-11-2004, 04:51 PM
Send a message via AIM to fintstone
Not sure which part you need...is this it?
http://www.eagleday.com/heco.html
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-11-2004, 04:55 PM
jpnovak's Avatar
Thanks for the sources. Those are exactly the parts I need.
James, I will check AZ tomorrow, Its close to the house and a block from the 7-11. Slurpees keep me going through the hot days around here!
Old 09-11-2004, 07:58 PM
I use Bosch high watt bulb connectors that has screws to attach the wires.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-11-2004, 11:44 PM
