Want to dress up my motor
I have the carbs of my 70 t being rebuilt and I would like to dress up the motor. I was going to start with painting the fan and the fan strap. Should these be powdercoated. Has anyone done them themselves. I was also going to have the throttle bar (piece between the two carbs connecting them) painted the same color. Then I figured why I was at it I would convert it to the K&N setup. Is this worth it. Any suggestions on what I can do and still have it be affordable. Thanks.
I read Waynes book on removing the fan but it didnt say anything about painting. Any suggestions would be appreciated.
Old 09-12-2004, 11:08 AM
Randy Webb's Avatar
I would go with basic black and a string of pearls.
The K&N is fine for carbs but no real adv.
Defintiely use powdercoat over spray paint - esp. for the fan which gets a lot of grit. Get the throttle bar and plated.
You can drill some big R type holes in the support crossbar and powdercoat silver.
There is a whole thread on "purty engines" somewhere on the BBS.
Old 09-12-2004, 11:14 AM
Polish the throttle bar? Do most people prefer the stock setup or the K&N?
Old 09-12-2004, 11:58 AM
Ok the car is signal yellow. Should I try to match the fan with the color of the car or go red or something?
Old 09-12-2004, 05:46 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
There is a guy here on the board that makes new shrouds anyway you want them. THey're under $200 and they really make your engine bay stand out.
Might be a little pricey but if your shroud is like mine it might be worth it.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 09-12-2004, 05:54 PM
who?
Old 09-12-2004, 06:14 PM
Tim Walsh's Avatar
series900
see this post
fan shroud question
I have a friend who's got one of his shrouds and the only way I could tell a factory part from the new one was the age, the new one's SOOO much nicer
Tim
1973 911T
2005 VW GTI
Old 09-12-2004, 06:53 PM
project 911's Avatar
I've had pretty good luck with engine paint on steel and fiberglass parts like the fan strap, shroud, tins, etc. I went with red and black with polished fan and valve covers. The polished parts stay nice for about a day... I've gone to a black wrinkle finish on the valve covers and inside the fan hub and it seems to be holding up fine.
70T engine in a 71T.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-13-2004, 07:36 PM
copper's Avatar
Steve B
Please tell me how you managed to get such a fantastic shine on your fan. I've been looking at several options. (Autosol etc.)
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 09-13-2004, 11:40 PM
Hi Jim,
My fan was really coroded when I got it, so first I sand blasted it and painted it red with engine paint, but the corosion came right back through the paint very quickly.
There was lots of pitting, so I actually had to use a file to smooth the whole thing out (hopefully you won't have to do this). After that I wet sanded by hand down to about a 600 grit (even finer would be better), then I buffed it with a bench grinder with firm cotton buffs using tripoli, then rouge. You need a buffing wheel that is a large enough diameter to reach the sides of the hub between the fins.
I found that rubbing WD40 into it helped keep it nice for a while, but it doesn't last long. Now I just clean it with Mother's polish, or 0000 steel wool soaked in WD40. It leaves a little more of a satin finish, but not bad. I haven't tried any kind of clear-coat.
Sure looks pretty when it is first done...
Now it is more of a satin look. This is before cleaning, so it will shine up a little better than this pic shows.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-14-2004, 04:58 AM
Same deal on the valve covers-
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-14-2004, 05:09 AM
copper's Avatar
Well done.
It truly is a sight to behold.
Of only there was some way to retain that mirror shine...
Jim
Old 09-14-2004, 10:22 AM
Thanks Jim,
My weather and location doesn't help. Fog, rain, snow... Even in the garage it all gets wet. I guess if I would have polished it more often, it may have stayed better, longer.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-14-2004, 10:55 AM
