shifter adjustment
Do you adjust the shifters for 901 transmissions the same way you do for the 915s?
i.e. lever all the way left and trans shaft all the way over the other way? |
Anybody know about the 901? I don't see it in the numerous threads on doing this for a 915....
Randy, I don't have any clue, but I'd bet it works about the same. You could verify that by opening up the access plate and watching it rotate. If you pull towards you (left), the 915 linkage rotates away from you (top of coupler moves right). The principle that makes that adjustment work ought to be the same.
Or if it isn't, at least you've got the bump, and someone who knows better will slap me around for being an idiot. (But then you'll have an answer, which is the point...)Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
