fuel accumulator
Hope some one can help, this is my first porsche, I was wondering if some one has any pics on where is the fuel accumulator and the fuel pump, im trying to fix my hot start problem, before porsches I worked on jeeps, so this is like learning a new launguage, 79sc
Old 09-12-2004, 08:27 PM
The accumulator is located on the drivers side up toward the firewall. The fuel pump is located under the car..you will have to remove a piece of sheetmetal to gain access. If you go on the seach and put fuel pump I am sure you will find pic of the accumulator and fuel pump. Just for grins...that engine has a check valve in the fuel pump that can be replaced. This will cause the hot start problem when the check valve has failed. I would start with the chep fixed before going with the accumulator.
Bob 80SC
Old 09-12-2004, 09:03 PM
