welder question
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4323372953&ssPageName=MERC_VI_RSCC_Pr4_PcY_BID_Stores
Will this welder work for doing body work, like cutting out a rot hole and replacing with new sheet metal? I have never welder before but I have come to the conclusion this weekend that I better learn.
Thanks,
Old 09-13-2004, 06:23 AM
Flux core wire is a bit messy and difficult for doing body welding. That unit looks like one of the cheep Miller knockoffs made in China.
Old 09-13-2004, 06:36 AM
Thanks, any good alternatives?
Old 09-13-2004, 06:37 AM
fuelie600's Avatar
I agree with Thom. Flux core is a bad way to go got body work. Sheet metal can be welded with a low power MIG, but you need shielding gas to do a decent job.
Evan
1987 sun roof coupe
Old 09-13-2004, 06:39 AM
Sounds like you're new to the welding scene; I'd recommend a Lincoln 115 with gas kit (I think that's the model #). It's a 110v welder that can use .023 and .030 wire, and has more capacity than you'd need for body work. Figure $500 for the welder, gas setup and all the fixin's. If you go this route, buy the adapter to use a 10lb wire spool from the get-go.
Old 09-13-2004, 06:59 AM
Go to a local welding supply shop. Many times they have trade-ins on relatively new, brand name equipment which they can back-up with a warranty. You'll most likely have a very tough time getting parts for the lower end Chinese and Italian equipment down the road...and then what? (personal experience talking).
Personally I'd save a bit longer and try to stick with the big brands and get as much welder as your wallet will allow....well, within reason. Great advice above as well...Gas is the way to go.
You'll want:
- as high duty-cycle and amperage as possible
- 220 unit if possible
- heat and wire feed controls with as much variabilty as possible
Consider it an investment if you plan to take the hobby seriously. You wont be sorry.
Warren & Ron, may you rest in Peace.
Old 09-13-2004, 07:06 AM
na2ub's Avatar
I got a Lincoln Electric Pro-100 which is a Mig Arc Welder. I have yet to convert it to a true MIG with shielding gas (which I certainly plan to), but used it with flux core to replace my suspension pan. I worked pretty well, but I would recommend upgrading to a shielded gas (MIG) type. Mine was about $300, as is, and is can be upgraded to MIG. I am very pleased with it.
Doug
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-13-2004, 08:33 AM
