Plugged CIS Adjustment Screw Hole
Having completed the re-build of the engine, we attempted to adjust the CIS mixture screw atop the fuel distributor, and found that there is a plug in it, or something is plugging it up. At any rate, can't insert the Allen-head adjuster.
Is there any way to remove the plug, short of dropping the engine again? Can't even see it, as the sound-deadening pad is in place, and there's very little room to look.
1983 911SC Chocolate Kiss (Smokey Quartz Metallic)
1991 VFR750F
1982 VF750S
Miata (wife's)
Audi A6 Quattro (family)
Old 09-13-2004, 05:10 AM
Somatic Negative Optimist
Gunter's Avatar
From '81 on, the access hole in the FD for mix adjust has an anti-tamper plug to prevent adjusting. (Emission control, air quality) The plug needs to be drilled out. Use a 2mm drill bit, carefully drill into the ALU core of the steel plug 3.5mm deep, then screw a small sheetmetal screw into the plug and try to extract. Bentley SC manual 240-8. Yes, you have to drop the engine enough to fit the drill motor with an extra long drill bit. It has to be done very carefully.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-13-2004, 08:34 AM
Andras- your car must be one of the very few that still has the plug intact.
Old 09-13-2004, 08:41 AM
