peridotian's Avatar
Simpleton question
Cannot get a hold of PO. What oil should I be using in my 3.0L 78 911 SC?
Patrick Pickerell
www.peridotcorp.com
74 1.8L 914
73 2.0L 914 (motor almost done!)
78 911SC Talbot Yellow (SOLD to a Pelican)
04 BoxsterS with tip (Wifes)
04 C4S!
Old 09-13-2004, 09:51 AM
Registered abUser
TerryH's Avatar
typically 20w-50w.... lots of it. Have you changed it before on one of these oil slingers? Not like changing on dads Olds.
'81 911SC Coupe SOLD
Old 09-13-2004, 09:56 AM
peridotian's Avatar
Just bought the car, oil is VERY clean, but low as indicated by the gage on dash.
Patrick Pickerell
www.peridotcorp.com
74 1.8L 914
04 C4S!
Old 09-13-2004, 09:57 AM
IROC's Avatar
This is a question that has many correct answers. I would offer to just pick your favorite brand name oil in 15W50 or 20W50 weight and live happily ever after.
Dino is fine, sythetic is better.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-13-2004, 09:58 AM
I would rather be driving
jpnovak's Avatar
Yes, 20W50 dino oil is std use. Careful when emptying, lots of oil comes out. don't forget to empty the tank and the engine sump.
Don't overfill. add when the engine is warm and you can measure while engine is running at idle.
Designer King
Paulporsche's Avatar
W/ engine running and warmed up, the level should be about 1/2 way between the 2 dipstick marks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-13-2004, 10:00 AM
Please search the archives before you add/change any oil...or you're likely to have a mess
ps: the guage on the dash is worthless imo...you have to check via the proper procedure.
pps: Congratulations on your new 911!
Old 09-13-2004, 10:18 AM
steve911's Avatar
Patrick--
As KC911 said, use the dipstick as the primary means of checking the oil level. Oil needs to be good and warmed up (temp gauge at 9 o'clock (or higher)) and the car idling on level ground. I've found that when the oil is not warmed up the dipstick AND the gauge are inaccurate.
I use my dash gauge as a kind of visual reminder since it does react to when the oil starts to get a little low (about a quart down).
Congrats on the new car - and please post pics
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 09-13-2004, 10:39 AM
Somewhere in the Midwest
MotoSook's Avatar
For your first oil change, make sure the oil is cool (it's OK to let it sit overnight when the weather is warm, the oil will still drain well enough...let it drain...and have a beer).
Until you have seen the oil draining live, you won't believe how fast it can come out of the tank. You do know that there is a case drain and a tank drain right?
Get the largest oil pan they sell as 9-12 quarts will drain out of the system. When you put oil back in, start with 8 quarts (make sure you have drained all the oil!...don't be like a Dealer wrench I heard of that didn't drain the tank, then added the book recommended number of quarts!!!!).
With 8 quarts added, start the engine and let it warm up, then check with the dipstick. Add until you are midway between the marks. Your engine should be running when checking, and it will hunt or drop in idle when you remove the oil filler cap. Don't worry about that, it's the CIS oil tank vent opened to atmosphere. When you put the cap on the tank filler, the engine will return to normal RPM.
Don't drop the dip stick in the tank. Guide it into the tube carrier in the filler neck.
Now, why have oil cold on your first change...it'll drain a little slower and it won't burn you. Slower is better your first time, and if it's hot, you'll get a good burn when you go to try and plug it with the drain plug to slow it down.
Good luck...and used the Mahle filter...don't go cheap in the filter.
I use Castrol 20/50 for above 10 deg. F driving. Your high mileage SC will likely leak with synthetic...just use Dino oil and change it regularly.
Old 09-13-2004, 10:53 AM
Yes. Warm, level, and running..... like Steve said!
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 09-13-2004, 10:54 AM
na2ub's Avatar
The dipstick reads 2 quarts from low to high marks. The dash guage reads 1 quart, low to high (in my experience). Therefore, when the dash guage reads low, the dipstick reads middle. Make sure you check the oil on the dipstick when hot.
Doug
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-13-2004, 11:58 AM
R Wilco's Avatar
I had a great drain pan till I left it in the alley draining into my PC receptacle. I left it over night as it had some previous sludge. I go out the next morning and it's gone. So I hunt around town and find this great 12 quart heavey plastic job. I usually warm the car up for a minute or so to get the majority in back in the tank. I pull the plug and didn't realize the hole in the middle of the new receptacle was to small. I felt like the monkey trying to stick the cork back in the pigs ass. Oh well.
Old 09-13-2004, 12:10 PM
Oil Pan:
The best tip I have seen so far, is to go to Home Depot (or whatever store you have access to) and go to the masonry section. For about $4 you can buy a huge pan, with tall sides that can hold way more oil than your flat 6. Plus, there is no hole in the middle to restrict flow. Even better is that is is wide / long enough that you can actually drain BOTH the sump and tank at the same time. Have to drink your beer faster though
It also doubles as a parts washer.....
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 09-13-2004, 02:08 PM
Wavey's Avatar
Also get in the habit of letting the engine idle for a minute before your shut it off. If the oil level is correct you'll see the gauge come up. Letting it idle will lower the oil level in the crankcase and raise it in the tank, and you will avoid the puff of smoke on cold startup.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 09-13-2004, 02:21 PM
Don't know if anyone said this, but if your dash gauge is somewhere in the middle you're probably okay. Dipstick check is best. If you're worried about being a quart or even two low and harming the engine, don't be. It's not like having a five quart car and being down half your oil.
'80 SC
Old 09-13-2004, 03:07 PM
I'm not here.
K. Roman's Avatar
Has anyone used 10W40?
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 09-13-2004, 03:38 PM
I just got burned with a new drain pan as per above. My old one develloped a crack, so I bought one with the covered top and a hole in the middle. (This way I'm thinking one of kids can't step in the oil that I haven't instantly put away.) Of course, as mentioned above, the damn hole is too small to stay ahead of the volume of scalding oil that issues from the tank. And even if it could, the closed top serves to splash the first blast of oil all over the place. I want my old pan back!!!
Ken
1986 930 2016 R1200RS
Old 11-26-2004, 08:19 PM
randywebb's Avatar
you will want to flush the brake fluid an dchange the rubber brake hoses
also change the trans. oil.
if the engine oil looks very clean and is pretty new, you could just wait 2,000 miles...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-26-2004, 08:44 PM
