Angry 81' NOW blows smoke !!!!!
I wish I would have went with nikisil Cyl,...My 3.0 now blows smoke on start up...it was doing GREAT until this morning...hit the key and Puff...what a shame...and it pisses me off...the car has almost 500 miles on the top end re-build...any chance it could go away..???????????? Thanks Frank
Old 09-25-2004, 10:27 AM
Did you overfill the oil?
Joe
Old 09-25-2004, 10:33 AM
anthony's Avatar
I thought they all blow smoke occasionally on startup?
Were you parked on an incline? I ask because my '81 doesn't normally smoke on startup when on level ground but when it's parked on an incline it will blow a huge cloud.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 09-25-2004, 11:20 AM
Yes, they CAN blow smoke but this engine only has 500 miles...I never dreamed that it would, and it's on a flat surface ...Well,..I might be a QT hi but, I'am not on the max mark...And yes it sits about 27" hi in the rear but...I would'nt think that matters. Does the oil ring rotate inside the Cyl. they fit tight when I assembled...I have not used any oil in those 500...Thanks Frank
Old 09-25-2004, 12:10 PM
Somewhere in the Midwest
MotoSook's Avatar
The rings can rotate. We've had to take the top end off and rotate them, then give them a good breaking in.
What was your break in process?
Not saying you'll have to take it apart, but it's possibility.
Old 09-25-2004, 12:13 PM
I followed Wayne's instruction's in the rebuild book,..to the letter...and it went great until today,..I need to re-torque the heads ,and 500 mile valve adj, but I bet its ring slipage.FM
Old 09-25-2004, 12:27 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
You know, at about 150miles into my top end rebuild, it started to puff on started up. I started freaking out thinking i did something wrong, then about three more cold starts after that it stopped. So i checked the oil level and it was a hair under the full mark, oops.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 09-25-2004, 01:23 PM
My motor has a total pro rebuild about 4k ago. It smokes on every other start-up or so. It gets more than 1000 miles to a quart, however. I had a leakdown done on it at pre-purchase two months ago. Less than 10% across all 6. I was told (here and by mechanic) the smoke was a normal condition for a boxer motor.
Venetian's Avatar
Prior to my top end rebuild, my 1987 Carrera smoked on start up and got approx 600 miles per liter. After the rebuild , it rarely smokes on start up and gets approx 2000 miles per liter. Break in consisted of varying the RPM for the first 1000 miles.
1987 Carrera, Venetian Blue.
Old 09-25-2004, 02:50 PM
Hey....Thanks for the Info guys...I'am ok with a little but I still hope it goes away ...I shall monitor the issue for the next few thousand miles....Thanks Frank
Old 09-25-2004, 08:31 PM
1fastredsc's Avatar
One more quick tip, in order to properly seal ausil rings/cylinders during break in, I've heard and tried the accel/decel method of accelerating hard to 5k rpm then letting off the throttle and coasting down to 3k rpm, then repeat.
2007 Mazda 3 hatch
Old 09-25-2004, 11:42 PM
Sounds like fun...My car has 964 cams and I enjoy the various RPM'S Hope it pays off ...I 've got 500 more miles for break-in, So I shall do it wisely.Thanks FM
Old 09-26-2004, 10:12 AM
