amersbell's Avatar
Porsche Crest Will SSi's for 3.6 fit 3.0?
Will SSi's for a 3.6 vario fit on a 3.0 engine with minor modification?
Chris Bell
Confused owner with more 911 questions than answers......and no one to ask in West Texas.
1971 Targa, 1981 911 SC Targa, 1995 993 Coupe
2008 Cayman
Old 09-14-2004, 06:59 AM
Friend of Warren
I don't believe they make SSI's for a 3.6. But I could be wrong.
Kurt V
Old 09-14-2004, 07:03 AM
amersbell's Avatar
There is a guy selling some from his 3.6. He said I would need to change oil lines and longer studs.
Chris Bell
2008 Cayman
Old 09-14-2004, 07:46 AM
Friend of Warren
Are you sure he has a 3.6 and are you sure he said SSI's and not just factory heat exchangers. In any event if it is a 3.6 SSI does not make a heat exchanger for that engine and stock 3.6 heat exchangers will not fit your 3.0. Maybe he means a 3.2 engine.
Kurt V
Old 09-14-2004, 07:53 AM
amersbell's Avatar
Kurt,
Take a look at this ebay ad.
http://cgi.aol.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7921589621&sspagename=ADME%3AB%3ASS%3AUS%3A1
Chris Bell
2008 Cayman
Old 09-14-2004, 08:56 AM
Friend of Warren
Ah now it makes sense. SSI does make heat exchangers for a 3.6 transplanted into an earlier 911. Pelican sells them. Pelican lists them as different stock numbers than for the 3.0 and 3.2 engines. Should fit, but may have problems plumbing the heat. Maybe someone else will jump in here.
Kurt V
Old 09-14-2004, 09:08 AM
I think Bill V ran SSI's on his 3.6 until he went with headers.
amersbell's Avatar
Heat is rather important. The guy told me the flanges are pretty thick but that other than that they should fit. Don't wanna waste money.
Chris Bell
2008 Cayman
Old 09-14-2004, 09:13 AM
Bill Verburg's Avatar
Yes, there are 2 basic models of SSI thick flange and thin. Either can be used on a 964 3.6 or 911 3.0. At worst studs will need to be swapped.
A 964 3.6 will want thick flange SSI, so assuming theat is what is there the 3.0 will need the longer studs to acccomodate the thick flanges. If they are not present then swap spome long ones in , not a big deal.
Now the part about the vario is confusing because the 993 vrams have reversed stud pattern on the right bank of cylinders. I hope that the studs were changed to accomodate the SSI pattern and not vice versa.
Bill Verburg
Old 09-14-2004, 01:27 PM
amersbell's Avatar
Bill,
Is there any way to tell by looking at the photos?
Chris Bell
2008 Cayman
Old 09-14-2004, 01:33 PM
Yes, but I can't show you because this site is FUBAR
Bill Verburg
Old 09-14-2004, 01:41 PM
amersbell's Avatar
Are these SSI's headers here or are they just heat exchangers?
Chris Bell
2008 Cayman
Old 09-14-2004, 01:54 PM
Friend of Warren
Those are stock 3.2 heat exchangers.
Kurt V
Old 09-14-2004, 01:58 PM
No, they are not SSIs they appear to be 3.2 or 964 ss exhausts.
Hurray at last some thing works
Thick flange SSI
Bill Verburg
Old 09-14-2004, 02:01 PM
amersbell's Avatar
Well, I think I'll try for the ones on ebay and see what happens.
Thanks guys for all your help.
Chris Bell
2008 Cayman
Old 09-14-2004, 02:02 PM
unimog's Avatar
I think they are standard thick flange SSIs that have had one side of the heater exchanger tin changed to use the later ducting (single side off the top of the fan) instead of the earlier two side ducts. Bill's pictures is a great example of the standard thick flange 'early tin'. Heck it looks like everything is there, so you should be set. A very good price if it stays in that range for the SSIs and the muffler.
Good luck with your bidding, and watch out for some guy on eBay that goes by 'unimog' sniping you. (just kidding I already have a set)
'04 BMW R1100S BCR
'01 Audi TT RS
gone but not forgotten:
'87 911 Carrera '59 356 Coupe
'66 912 Speedster '99 996 Ducati
Old 09-14-2004, 07:16 PM
jpahemi's Avatar
Don't the thick flange SSI's have a section that goes into the exhaust port? A type of tapered cone?
J.P.
Old 09-14-2004, 07:40 PM
Bye, Bye.
Scooter's Avatar
Sold for $571, but unfortunately not to Chris.
Elvis has left the building.
Old 09-14-2004, 09:34 PM
Senior Member
Someone got a good deal! The SSI's there are worth more than the price of the auction without the muffler nor heat ducting.
JoeA
Old 09-14-2004, 10:02 PM
Now in 993 land ...
aigel's Avatar
J.P.
Mine do. And the stock exchangers do too, that you see further up. I have heard people call them 'gasket savers' or 'gasket sleeves'. I think their purpose is to keep pressure off the gaskets and they may create a smoother flow.
I can't see why it wouldn't work without the sleeves tho.
George
81 SC (sold)
Old 09-14-2004, 11:38 PM
