Will SSi's for a 3.6 vario fit on a 3.0 engine with minor modification?
Chris Bell Confused owner with more 911 questions than answers......and no one to ask in West Texas. 1971 Targa, 1981 911 SC Targa, 1995 993 Coupe 2008 Cayman |
Friend of Warren
I don't believe they make SSI's for a 3.6. But I could be wrong.
Kurt V No more Porsches, but a revolving number of motorcycles. |
There is a guy selling some from his 3.6. He said I would need to change oil lines and longer studs.
Friend of Warren
Are you sure he has a 3.6 and are you sure he said SSI's and not just factory heat exchangers. In any event if it is a 3.6 SSI does not make a heat exchanger for that engine and stock 3.6 heat exchangers will not fit your 3.0. Maybe he means a 3.2 engine.
Kurt,
Take a look at this ebay ad.
Friend of Warren
Ah now it makes sense. SSI does make heat exchangers for a 3.6 transplanted into an earlier 911. Pelican sells them. Pelican lists them as different stock numbers than for the 3.0 and 3.2 engines. Should fit, but may have problems plumbing the heat. Maybe someone else will jump in here.
I think Bill V ran SSI's on his 3.6 until he went with headers.
Heat is rather important. The guy told me the flanges are pretty thick but that other than that they should fit. Don't wanna waste money.
A 964 3.6 will want thick flange SSI, so assuming theat is what is there the 3.0 will need the longer studs to acccomodate the thick flanges. If they are not present then swap spome long ones in , not a big deal. Now the part about the vario is confusing because the 993 vrams have reversed stud pattern on the right bank of cylinders. I hope that the studs were changed to accomodate the SSI pattern and not vice versa.
Bill,
Is there any way to tell by looking at the photos?
Yes, but I can't show you because this site is FUBAR
Are these SSI's headers here or are they just heat exchangers?
Friend of Warren
Those are stock 3.2 heat exchangers.
No, they are not SSIs they appear to be 3.2 or 964 ss exhausts.
Hurray at last some thing works Thick flange SSI
Well, I think I'll try for the ones on ebay and see what happens.
Thanks guys for all your help.
I think they are standard thick flange SSIs that have had one side of the heater exchanger tin changed to use the later ducting (single side off the top of the fan) instead of the earlier two side ducts. Bill's pictures is a great example of the standard thick flange 'early tin'. Heck it looks like everything is there, so you should be set. A very good price if it stays in that range for the SSIs and the muffler.
Good luck with your bidding, and watch out for some guy on eBay that goes by 'unimog' sniping you. (just kidding I already have a set)
'04 BMW R1100S BCR '01 Audi TT RS gone but not forgotten: '87 911 Carrera '59 356 Coupe '66 912 Speedster '99 996 Ducati |
Don't the thick flange SSI's have a section that goes into the exhaust port? A type of tapered cone?
J.P. |
Bye, Bye.
Sold for $571, but unfortunately not to Chris.
Elvis has left the building. |
Senior Member
Someone got a good deal! The SSI's there are worth more than the price of the auction without the muffler nor heat ducting.
JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Now in 993 land ...
I can't see why it wouldn't work without the sleeves tho. George |
