Can 964 fan+housing fit 3.2 Carrera?
Hi folks,
I have a crack in my fan housing of my 87 Carrera. Since I have to buy a replacement housing, would a 964 12blade fan and housing (with alternator changed too) fit into my Carrera?
Has anyone else done this?
Thks!
Old 09-16-2004, 07:45 PM
Bill Verburg's Avatar
The Carrera fan flows more air @ a given rpm than the 964 fan. Why would you want to switch?
Bill Verburg
Old 09-16-2004, 07:54 PM
Hi Bill,
Thks for the info. I actually thought the 964 fan flows more air (new design, 12 blade fan, etc etc).
Other thing I noticed is that there are 2 belts (one for fan and one for alternator) which makes the conversion even harder as I have air con on my car.
Any idea why the 964 uses separate belts for fan and alternator?
Thks!
Old 09-16-2004, 08:57 PM
Randy Webb's Avatar
No, the new design apparently went into noise reduction technology.
Old 09-16-2004, 09:16 PM
...is my Daughter
Avery's Avatar
Bill's comment that the Carrera fan flows more air is interesting. So would changing over to a CArrera fan on a 3.6 be considered an upgrade? Is this a feasible "backdate"?
Felmir
Keep Going!
Felmir Singson RGruppe #479
"Living the rest of my life, one minute at a time"
Old 09-16-2004, 09:34 PM
Randy Webb's Avatar
Hmmm, well you really don't need it do you? I think they are different sizes, but with cubic dollars nearly anything can be adapted.
Old 09-16-2004, 09:48 PM
l`ve always heard that the 964 fans flow less air at the expense of noise reduction,but still allow adequate cooling. They look better then the earlier fans though,don`t they?
my life begins at 150MPH
Old 09-17-2004, 12:47 AM
hi Raceman,
hmmm....YES (Homer's voice).
Yup, thats one reason why I was thinking of the 964 fan since my housing is cracked. My wrench tells me its plug and play but the belts need to be changed
But if the airflow is reduced......
Old 09-17-2004, 12:57 AM
There are lots of old posts on the fan flow rates here is one
Old 09-17-2004, 04:00 AM
Green Skull 006
Jim Garfield's Avatar
After reading through these:
Any aftermarket highperf. fans available?
I really find myself missing Roland's input!
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 09-17-2004, 05:37 AM
