Tail light assembly - removal
Is there some way to disconnect the tail light assembly on a 77 911. Is there an electrical connection or something similar?
I would like to remove them from my car.
Thanks,
Old 09-27-2004, 12:50 PM
I would first unplug the wiring harness connection in the corner on each side of the engine compartment, this gives you a little more wire to work with. Then you will need to remove the lense from the housing. Once that's removed there are two screws which hold the housing into the rear quarterpanel. Once you get those removed you will need to unscrew the back cover on the housing to gain access to the wires to unplug them from the terminal. That should pretty much do it. Good luck.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 09-27-2004, 02:08 PM
