Fitting Webbers to CIS Heads
I am fitting a set of 40 Webbers and standard early intake manifolds onto a 2.5 motor with 2.7 CIS heads with 32mm ports.
Do I need to "fill" in the CIS notches on the heads and if so what is the best method?
Robert
Old 10-01-2004, 07:07 PM
Oops - Just noticed that I posted on the wrong board. How do i move or delete the post?
Robert
Old 10-01-2004, 07:19 PM
I would rather be driving
jpnovak's Avatar
The easiest way is to call/FAX PMO carbs. They sell a carb/head insulator that is specifically shaped to cover the CIS injector port. They are oblong versions of the std. carb gaskets.
http://www.pmocarb.com/
Old 10-02-2004, 07:08 AM
