Headlight utopia?
I know there are lots of you out there that just can't get enough light out of their headlights and I ran across some interesting information. Anyone ever tried the PIAA 180/135w h4 bulbs?
http://www.piaa.co.uk/bulbs/bulbshow.asp?ID=halogen Also my roomie showed me this which is interesting. Looks like he built a voltage regulator for his h4 powered flashlight to bump the voltage up to 16v and got 3x the (measured) light out of it. http://www.candlepowerforums.com/ubbthreads/showflat.php?Cat=&Number=625755&page=0&view=collapsed&sb=5&o=&fpart=1 Wow, suddenly my 30 amp relays don't seem so overkill anymore
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
I would rather be driving
Tim have you read this? Look at the tech section.
http://www.danielsternlighting.com/ Some very good points are made. Those PIAA bulbs are a bit expensive, nearly $90 each. I think I will stick to the stock bulbs for now. I don't think that those boosted bulbs will last very long. There are many things you can overdrive with I or V. Most of the limits given by the manufacturer is based on a certain lifetime. Back in my bike racing days it was common to boost a 12V headlight to 13.2V and get more light out. The bulbs had but a fraction of their normal life. Unfortunately there is always a tradeoff.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Yep, read and re-read daniel stern's site. Tons of good info.
as per Dans recommendation I use Narva bulbs, Cibie Euro lens, Bosch high current bulb sockets, etc.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
GAFB
FAQ temporarily unavailable
![]() Anyone got a copy?
Several BMWs |
Automotive Monomaniac
Best upgrade I ever did to my 911 was the H4 and 80/100W bulbs (plus relays).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Read some of the magazine bulb tests. My recollection is that PIAA come out really badly.
I remember one fairly recent review in www.autoexpress.co.uk. I think some of this is available on-line at the website.
"Racing is Life. Anything that happens before, or after, is just waiting" 1988 Carrera 3.2 Sport Coupe - my mistress 2012 BMW F11 touring - the dog bus! 2017 VW T6 Transporter - the holiday bus/workhorse |
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
hmm...I had a set of H4 PIAA Super Whites when they first came out and I loved them..
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Hey Emission, where did you put the relay? Between the head lights and the switch? Thanks jeff. By the way, smog check go ok?
An easy test is to drive as the only car at night on an unlit straight road and see if you can see down the road far enough to safely stop at 80mph if you came across garbage imo.
Look,
Not sure where emission put the relays, but I took the existing headlight wire and wired it into the control side of the relay then wired up the slave side of the relay into the headlight straight from the battery, to a fuse, into the relay and from there into the headlight.
Bandwidth AbUser
Tim, RoninLB has the hot setup. His headlights don't p-off oncoming traffic and yet I've never seen such great visibility at night. Give Ronnie a shout.
Jim R. |
The PIAA ultra-expensive 'enthusiast' bulbs are all hype and aimed, so to speak, for the ricers' market. The claimed light 'output' is testing gimmickery, and probably just a normal 130W/100W or 140W/100W H4 'true' power bulb with hyped ratings to 'justify' the ridiculous pricing!
Hella has the two highest power H4 bulbs on the market in their normal halogen line ... not even grouped in the blue 'Xenon Premium' or 'Yellow Star Premium' lines! #78141 140W/100W H4 #78173 165W/100W H4
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
(Thanks for asking. I have't had time to address the smog issue as I've been very focused on a huge project at work - I am self-employed. This weekend, I need Porsche car time for a stress relief.)
Emission, Thanks for the tip on the relay.
Self employment is the greatest. You neither work to death, or looking for work. The good thing is that you can take a day, or at times, weeks when the project permits. Put a another lic. plate on the 930 for stress relief this weekend. Good luck, just don't get in trouble. Jeff |
http://members.rennlist.com/msucro1/relaykit.htm
Me like track days
Real world experience:
I tried the 100/150 Hella bulbs - no rice bulbs, just good high wattage German jobbers. Installed a PIAA relay - did it all professionally, a nice install. Kept burning out bulb$, about 1 per month! Went back to the standard bulbs. FWIW,
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I've never had a single issue with my 80/100W bulbs (never replaced any either).
Me like track days
Hella does make bulbs:
http://www.hella.com/produktion/HellaPortal/WebSite/Internet_usa/ProductsServices/Performance_Lighting/Performance_Lighting.jsp I had the Hella 100/150 bulbs -
