Imcoz's Avatar
Question power begins loss at 4000 RPMs-help!
Chasing the issue w/ my 88 911 down for a while now. Replaced O2Sens, Head Temp Sens, full tune-up, tested air flow sens, coil, fuel pres... all passed. When I tested speed and ref sens 1+3 showed good, just showed open circuit when testing the other pin combos???? anyone familiar w/ this?
BTW runs/revs/drives perfectly 'til 4K rpms whether under load or not. Always gets rough at 4K in any gear.
Any all suggetions welcome.
Chris
88 Carrera
99 Boxster
Coz
88 911
72 914-6 Vintage Racer
76 914-6 Vintage Racer
Old 09-18-2004, 09:35 PM
kqw kqw is offline
Chek the operation of you WOT sensor.
The Fox
Carrera
Old 09-18-2004, 10:15 PM
Imcoz's Avatar
Thanks for your suggestion
The Fox,
I'll see where it ties in and see if I actually tested it already, Thanks again!
Chris
Coz
88 911
Old 09-20-2004, 09:06 AM
Limbo
Slider79SC's Avatar
Mine was doing this when I had issues with the distributor advance.. just .02
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 09-20-2004, 09:18 AM
Imcoz's Avatar
Thanks for the help... to no avail. Distributor seems right... WOT was good when tested. Others have suggested rust in tank screen, and vacuum lines to fuel pres reg... do somemore looking tomorrow.
Coz
88 911
Old 09-24-2004, 05:15 PM
Jim Smolka's Avatar
Clean and then reset the gap on the flywheel & speed reference sensor.
Also, check the inside the dizzy for rust.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 09-24-2004, 05:18 PM
kqw kqw is offline
Check the gap on your plugs...They should be set set at .28
The Fox
Carrera
Old 09-24-2004, 05:52 PM
Imcoz's Avatar
Have reset gap on Ref & Speed sensor... if ref was off it wouldn't start and if speed sensor was off it would be missing at low RPMs.. but it could still be off a bit so I'll check it again. Checked plug gap last week.
Thanks for the help all.
Coz
88 911
Old 09-24-2004, 06:18 PM
pwd72s's Avatar
I could be wrong, because I usually am. But I think I'd start checking fuel volume delivery...
Old 09-24-2004, 06:25 PM
kqw kqw is offline
Before the swap party begins, check the fuel mixture. Then:
I'd begin with ignition parts: Coil, Dizzy (shaft for sideward movement)cap and rotor.
Keep us informed...
The Fox
Carrera
Old 09-25-2004, 02:50 PM
The spring loaded weights inside the distributor may be seized preventing the rotor from rotating as rpms rise to match the advance curve with the distributor cap.
Joe
Old 09-25-2004, 03:23 PM
I don't think there are any weights in the distributor on the 3.2.
I think all advance is handled by the DME.
'69 911 Targa w/ 3.2
Old 09-25-2004, 04:11 PM
Mine does.
86 3.2
Old 09-25-2004, 09:55 PM
Diss Member
Quicksilver's Avatar
The springs/weights in the 3.2 don't control the advance. The DME does all that. The reason they are there is to make sure the rotor is pointed correctly towards the cap's contacts as the advance is increased.
It does sound like it is running out of fuel. Also if the coil is weak it could be having trouble sparking as the cylinder pressure rises.
You said the fuel pressure had been checked. Was it only at idle or was it under load. Also a spark energy problem would show up on the scope.
By tuneup did you mean Plugs, Cap, and Rotor? Also the increased spark resistance at higher cylinder pressure can make plug wires rear their ugly head under higher throttle settings. (but it should be just as bad at 3000 as at 4000.)
Good luck
Wayne
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-25-2004, 10:48 PM
Jim Smolka's Avatar
Hopefully, the plugs installed were of the plain NGK or Bosch type. Platinum plugs are not usually recommended for Carreras. Also, there is a tech note from Porsche stating that Anti-Seize on the SP threads is not remmended.
'81 SC 3.6 (Beast)
Old 09-26-2004, 04:54 AM
...and if the rotor is not pointed correctly towards the cap's contacts at 4000 rpm as the advance is increased, then what what happens?
Does it keep on running like nothing has happened?
Does it start to miss, sputter, act up, get rough etc?
Old 09-26-2004, 07:47 AM
WydRyd's Avatar
Check the simplest and cheapest things first. Check all your vacuum lines to the factory fuel pressure regulator and damper etc...
I had the same problem on my blown 3.2 (well, 3.3 now), and it turned out to be a disconnected vacuum line to the FPR
Good luck!
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-26-2004, 04:03 PM
Imcoz's Avatar
Thanks for all the brainstorming on this....
Yes... tuned means cap, plugs, rotor, wires, fuel filter, air.... I did test the fuel pressure at carside not under load. I have not counted out fuel delivery because the car sat for a year, but it was started. I have seen some postes reccomending a fuel pump be replaced especially if it is original. Also replaced the DME relay.
Used NGK when replaced... did put a little antisieze on the threads but only very little... have always done this w/ all my 911s w/out any issues.
When it loses power it feels as though it's out of gas... but returns to running fine as soon as you lift the throttle a bit to under 4K. I will look further into fuel pressure/vacuum issues again as soon as I can get my hands on my buddies Bosch fuel pressure test kit this week.
Thanks again all.
Coz
88 911
Old 09-27-2004, 10:40 AM
