Send a message via Yahoo to 911Brian
Help replacing rear shocks
I am in trying to install new rear shocks in my SC. While I am turning the lock nut on the top, the shaft is spinning. Does anybody have any ideas on how to stop it from spinning.....
86 Carrera Red/Black
80 SC Coupe Silver/Black (gone but not forgotten)
Old 09-19-2004, 12:17 PM
Randy Webb's Avatar
Impact or grip the shaft w/ vice grips - can pad with rag
Old 09-19-2004, 12:25 PM
abisel's Avatar
Does the top of the shock shaft (where the nut goes on) look like an allen wrence will fit?
Old 09-19-2004, 12:35 PM
North Coast Cab's Avatar
The old strut should have either an allen head on the shaft or a sort of square head. Either way you need to keep the shaft steady from the top while you tighten the nut. A 17mm? ratcheting box wrench makes this much easier as there isn't a lot of room.
John
1985.5 944 GTS
Old 09-19-2004, 01:07 PM
Thanks! I got the old ones off. I am having a heck of a time putting the new ones in. Not alot of room. I don't remember what the new shafts look like but I will figure something out.
Old 09-19-2004, 02:16 PM
19 years and 17k posts...
azasadny's Avatar
My new Bilstein's had a socket at the very top that required an allen wrench to hold the shock and prevent it from turning while I tightened the nut.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-19-2004, 06:05 PM
I will check it out. How did you get 2 hands in there? I am having a hard enough time with just 1 hand doing the job.
Old 09-20-2004, 06:39 AM
Formerly bb80sc
Vipergrün's Avatar
Use an "L" shaped allen wrench with the short side in the top of the strut. When you tighten the nut, the allen wrench will rotate. Where ever you are able, wedge a small block of wood as a stop for the allen wrench. There, now you only need one hand
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 09-20-2004, 08:22 AM
-B
I'll give it a whirl
Old 09-20-2004, 08:41 AM
azasadny's Avatar
911Brian,
I replaced my rear shocks while I had the engine dropped so it was easy. I also replaced the engine compartment sound pad and the motor mounts and rear engine bracket, as well as all fuel lines and vacuum hoses.
Art Zasadny
www.ford.com
Old 09-20-2004, 01:46 PM
