Tylermelvin's Avatar
Rear-Passenger lights not working
1978 911 SC 3.0
So, my rear passenger side tail lights not working; everything~brake, blinker, stop, signal..whatever you name it, it’s out!
I replaced all but the tiny bulbs, greased and lightly cleaned the contacts as much as I could. Checked the 11 fuse, and seeing as it’s only that entire fixture I’m curious if it’s just the entire fixture likely rotted on the inside even though I’m pretty sure this happened before and I had my mechanic replace it about 4 years back.
Could I check any wiring and where, any assistance is helpful.
Old 07-03-2018, 06:03 PM
Sounds like a ground problem.
Dave
1969 911T Coupe
1972 911E Targa
Old 07-03-2018, 06:28 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Diode.
Have a look at the attached diode on the light switch.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-03-2018, 06:50 PM
Gerry
By taking the housing apart?
Old 07-03-2018, 10:30 PM
Tomorrow I’ll be checking the two I’ve heard of being related to the tail lights in the trunk..
Do you have any idea of all the necessary locations?
Old 07-03-2018, 10:32 PM
I checked the relay (turn signal) and one prong is burned out, I’ll be replacing it tomorrow.
Old 07-04-2018, 07:29 PM
