Early 911 brake upgrades
Hi Guys.
I have a 1974 911 that I wish to track on the weekends.
Please let me know who makes a nice kit. I wanted to use 993 twin tubo brakes in the front and back, but the racer's group suggested using the C2-Turbo on the rear instead.
Any advice would be appreciated.
Thanks!
Not many people lay on their death bed and think that "I really wish that I had worked more." Have fun while you're young.
Old 12-21-2004, 11:49 AM
Az911's Avatar
Send a message via AIM to Az911
What problems are you having with your stock brakes?
72T RS look
96 993
Old 12-21-2004, 11:53 AM
dweymer's Avatar
Check out this page, Bill is regarded highly here.
http://home.nycap.rr.com/wmv/generalbrmd.htm
Donnie
Currently Porsche-less.....
Old 12-21-2004, 11:54 AM
Bill Verburg's Avatar
If its a plain 911(not S or Carrera) plan on starting w/ a set of struts
Bill Verburg
Old 12-21-2004, 01:58 PM
It is a plain 911. So you recommend that I get a set of upgraded struts to make it easier to fit the brakes to?
Thanks.
Old 12-21-2004, 04:29 PM
jmz jmz is online now
jmz's Avatar
tons of info here, suggest you search the site and use it as a primer. You will need to buy new struts. Any upgrade that is worth doing won't fit on the early struts unless they were equipped with S-Calipers.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 12-21-2004, 04:36 PM
jmz's Avatar
additionally, if you have a stock motor you aren't going to need much in the way of upgrades to track the car. ...at least when you start. Just use good brake fluid, replace your brake lines, use good pads and make sure you have adequate cooling to the brakes.
Old 12-21-2004, 04:38 PM
Porsche Doc's Avatar
Thumbs up
There is what I have been installing on track and street 914s & 911s for the last 20 years. There a great low cost upgrade!
The front calipers are ATE 4 pistons and the pad size is just a little smaller than a 930 pad.
The rears are ATE 2 piston with a pad size the same as the front 76-89 911 caliper.
They use standard F&R 911 rotors and fit 15" wheels.
The fronts bolt right on and the rears you have to grind a very small amount off the alum. trailing arm.
If you have the steel trailing they just bolt on.
The brake bias stays the same as orginal.
They work great!
The best thing they only cost $1000.
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 12-21-2004, 05:08 PM
RallyJon's Avatar
Are those iron BMW calipers?
993 · 911 · STI · S4 · rally car
Old 12-21-2004, 05:57 PM
The rears are with mods. There the 320's.
Thanks!
Old 12-21-2004, 06:06 PM
jmz's Avatar
a lot of 914 guys really like the BMW 320 brake upgrade. heard it works very well.
Old 12-21-2004, 07:53 PM
It's been pointed out, correctly, that the biggest problem is heat and to that end cooling and bigger rotors are the solutions.
Old 12-22-2004, 04:03 AM
dweymer's Avatar
Bill- which struts have the 3.5 spacing? I also have a 74, and will do this down the road a bit.
Donnie
Old 12-22-2004, 04:14 AM
Jeff Alton's Avatar
Doc, which rotors does your kit use? SC or carrera? Are the rotors included in the kit, or just calipers?? What is the selection like for different types of pads?
Thanks, Jeff
www.turn3autosport.com
Old 12-22-2004, 08:11 AM
Thanks, Jeff
Hey Jeff,
They can be used with SC or Carrera rotors.
Only the calipers (loaded with street pads) come with the kit.
All types of pads are aval.
Happy Holidays
Thanks!
Old 12-22-2004, 08:34 AM
RallyJon's Avatar
So they were designed for 24mm rotors, but you think it'll be OK if they're used with 20mm rotors? What thickness rotors were the front calipers designed for?
If they're not from a higher end BMW, they look kind of like Volvo calipers, but not quite...
So what car did the fronts originally come on?
Old 12-22-2004, 08:49 AM
24 mm rotors orginaly.
Alpha
Thanks!
Old 12-22-2004, 09:25 AM
Any S, any Carrera any SC
Unless the '74 has been drasticly modified. An upgrade to stock Carrera fronts will be fine.
Keep in mind the rotors are the heart of any brake upgrade.
'74 uses exactly the same rotors as an '83 SC. If you change the caliper to an A the rotor stays the same and you only gain a little pad area which isn't a big deal and is certainly not needed.
at least w/ the Carrera fronts(caliper and rotor) you get a little bigger rotor, which is all that is needed, especially if you put cooling in, which should have been step 1 any way.
A fair rule of thumb, S/ SC brakes are good for ~200hp and 2200#, the Carrera fronts gets you up to ~ 250hp & 2500#, 930 brakes are good to 250 and 2500#, etc. gaining 500# or 50hp usually moves you up a step in brakes.
Bill Verburg
Old 12-22-2004, 03:54 PM
randywebb's Avatar
Just to nail this down...
Does any S mean any real S, or also include the 2.7L mid-1970s cars that PAG called S? e.g. 1975 911S?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-22-2004, 04:53 PM
Porsche Junky
mede8er's Avatar
Bill...please clarify something for me.....
I am updating to 18" Twists on my 82 SC...spacers are HUGE...I want to stick 993 brakes up front....will that combo allow me to go with a more narrow spacer?????
Thanks....
1986 930 RUF equipped
Old 12-22-2004, 05:00 PM
