Austin TX shop recomendations for CO adjustment
I need to have the CO adjusted on my '91 Turbo and don't know who to goto. Anyone have a recommendation?
I would rather be driving
I am sure Moorespeed could do it. If you know where the adjustment is I have access to a Gunson meter.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Yea I know where the adjustment is. You have the meter to measure the CO from the exhaust? Could possibly be a quick adjustment with the right equipment.
I used to use Moorespeed for all my service on my '88 but the last couple times they were to busy to get me in so I have up on them. |
That's the meter. If you know the specs we can adjust. Is the spec at idle, speed or load? IT is usually as simple as warming up the engine taking a measurement, adjusting (turning) a screw or bolt and remeasuring until its within range. Shouldn't take too long.
Jamie
Yea it is just a matter of setting the CO between 3 and 3.5 at idle. You just unhook the O2 sensor, put the meter in the exhaust and adjust at idle till your there. If you wouldn't mind helping that would be awesome
!!! Where in Austin are you located? I am in the Oak Hill area. |
I live in Central off Mopac and 35th. Another Austinite and pelican member has the Gunson. I am sure he would love to come help too. I think I am free this weekend. PM or email me your phone number and we can set up a time.
