-   -   Dynamat in Engine Compartment (http://forums.pelicanparts.com/porsche-911-technical-forum/184724-dynamat-engine-compartment.html)
chuckr 09-28-2004 07:36 AM
Has anyone used Dynamat in the engine compartment
in place of the foam pad the factory uses ?
I am looking for a way to clean up the engine compartment
and the sound pad is an eyesore. What about the
foil and felt pad that Performance and MidAmerica sells ?
Chuck
RoninLB 09-28-2004 07:55 AM
Re: Dynamat in Engine Compartment
yes
chuckr 09-28-2004 09:29 AM
Ronin,
How well does it work... how does it look ?
Do the ends fold down like the factory foam pad ?
Do you think you have more room in the engine compartment ?
Can you tell a difference in the sound inside the car ?
Thanks for your input
Chuck
MuffinMan 09-28-2004 10:06 AM
Pelican sells a silvery engine pad replacement, made by Appbiz. There are a bunch of testimonials on the site to that product.
Bill Verburg 09-28-2004 11:55 AM
I have Dynomat also, it works and looks fine
http://forums.pelicanparts.com/uploa...1096397607.jpg
What little can be seen anyway
This is a sister to mine, also w/ Dynamat
http://forums.pelicanparts.com/uploa...1096397668.jpg
The AppBiz one also works well
RoninLB 09-28-2004 12:25 PM
Ronin,
ditto, ditto, ditto Bill & Muffinman
I've used a lot of Dynomat in various places, so maybe I'm not the best example.
My act was to kill the tin can sound thus making the exhaust sound and audio much nicer.
There is also a very good Dynamat style lining called B-Quiet that's cheaper. Randy Webb has posted good audio sound deadner info fyi. Maybe search Randy's name and audio, Dynamat, etc.
Craig 930 RS 09-28-2004 12:48 PM
APPBIZ = very light and well made (can even get the edges finished - in colors no less)
Have one in the SC with 3.6 conversion
Randy Webb 09-28-2004 01:07 PM
My interest was in using the lightest wt. sound "deadener" - BUT not for the engine pads as shown above. I just used a new stock pad. It's light, already cut to fit, and obviously works. I don't see anything wrong with the alternatives above. Radiant heat will be reflected back onto the engine (until the shiny color is ocved with soot, dirt, grease, etc.) but I doubt this is significant. It's an experiment tho - and doesn't seem to have any adv. or save any $$ over the stock pad. Note - the ones sold now are lighter and more ong lasting thatn the ones that came on 1970's 911s.
