GFORCED's Avatar
Black Chrome
I have a turbo with black wheels, logo, windows, etc.
The exhaust tips are aluminum as you know, so I had them painted black with engine block paint. Well, it wore of and looks like *****.
What I would like to know is if anyone can tell me where I can either black chrome them or get them painted black (or colored black) so it will not fade.
2002 Porsche 911 turbo X50
2002 S500 Mercedes Benz "pimped out"
2007 Mercedes CLS 550
Old 09-24-2004, 07:43 AM
You could have them black anodized and that would look good. As many will tell you chrome does not work well on aluminum
Ben
Old 09-24-2004, 07:52 AM
Sky_King's Avatar
Take a look at http://www.caswellplating.com/kits/black_krome.html. If you're not interested in doing it yourself I would believe that someone there can either do it for you or offer help to you.
Joe
Joe
Akron, OH
jhale5@neo.rr.com
'01 996 Carrera Coupe
The Doctor is.... IN
Old 09-24-2004, 07:55 AM
GFORCED's Avatar
Sky_King,
Thanks for the tip, but it doesn't say for aluminum.
MB911, will the anodizing take the heat and not melt, chip or crack?
Old 09-24-2004, 09:00 AM
Zeke's Avatar
You can powder coat AL. Anodize will take lots of heat. Engine enmel is not the same as exhaust paint, which will also take the heat. If you want a low gloss, you can use bar-b-que paint. Just follow the instuctions and drive the car to cure it.
Old 09-24-2004, 09:11 AM
GFORCED's Avatar
Zeke,
I think you have solved my problem!!
Stove Bright has a a paint: High Heat Silicone Bar-B-Que Paint to 1100ºF. Designed for exterior all weather use, self priming on metal.
In Black semigloss!
Cool!
Old 09-24-2004, 09:15 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Chris, use Wurth high temp black. Painted my valve cover over two years ago, still shiny black
Old 09-24-2004, 09:23 AM
GFORCED's Avatar
Wurth withstands up to 1200 degrees F! $9.00 on your site.
And to think that ********* charged me $200 to paint the tips with Rustoleum that melted of in a week!
Thanks Jared. Should have 'em painted for our next run.
Old 09-24-2004, 09:34 AM
Might be a good idea to lightly scuff them up with steel wool, so the paint has a better surface to ahere to..
Old 09-24-2004, 09:36 AM
GFORCED's Avatar
Jared,
Just ordered it. Sure wish you lived closer so you could help me with this.
Thanks for the info!
Old 09-24-2004, 09:45 AM
No porblem. It really isnt all that difficult...
Just remove the tips, strip them down. Jasco paint stripper always works well, (use gloves and have plenty of ventilation)
One stripped, lightly scuff them up with steel wool or 1000 grit sandpaper. Clean the hell out of them with acetone or zxylene.
Once clean, spray a light tack coat, (if possible, put them in the oven at 350 degrees for about 20 minutes) After that, spray each coat and cure in the oven..
Afterwards, polish the hell out of them with Mother's Caranuba wax. This will level out the paint and make them look smooth.
Old 09-24-2004, 10:43 AM
Senior Member
Jdub's Avatar
Jasco or any paint stripper: First hot wash the item with plenty of soap so the stripper will apply to surface, not dirt. Expect to lay two coats on. Apply first coat and immediately put item in airtight bag: this will keep the volatile agents from evaporating and keep them working on stripping instead.
Use a body filler scraper or equiv. to remove what you can. Soft wire brush for remainder/corners. Reapply second coat of stripper.
John
'78 Targa in Minerva Blue
Old 09-24-2004, 10:47 AM
thanks Jdub, forgot to mention that.. And dont get Jasco on your skin.. "IT BURNS! IT BURNS!"
Old 09-24-2004, 10:49 AM
3.4 Bigger is better
88-diamondblue's Avatar
Check out the black chrome powder coat at http://www.columbiacoatings.com/1024t45676ty78yj789345erfrg5467.htm
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 09-24-2004, 10:58 AM
GFORCED's Avatar
Sounds like way too much work, but thanks for the tip.
GFORCED's Avatar
That looks like an excellent product as well. How come the paint guy didn't know about any of this stuff?
Old 09-24-2004, 11:01 AM
In a similar vein....can stainless steel exhaust tips be electroplated black ?
If so, can the tips ( mine are welded-on) be kept on the car during the process? You see so many Lexus' and such with their brand name badges electroplated gold....just wondering.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-24-2004, 01:15 PM
Gforced, Columbia also has a high temp powder that may be better. Either Columbia or a local powder coater may be able to help you.
Michael
2020 Honda Passport
Old 09-24-2004, 06:12 PM
GFORCED's Avatar
Here's the finished product with Wurth black. Cleaned with acetone, smoothed with steel wool and recleaned with acetone and blew dry everything with a compressor.
A few light coats and they looked excellent. I didn't even bother with the wax as the paint is very coarse and looks really cool.
Before:
After:
Old 09-28-2004, 03:43 PM
Looks great! glad I could help you out....
Old 09-28-2004, 03:45 PM
