One of the guys set up a day on a local Dynojet. I don't have a scanner at home, so I'll have to wait the post the graphs, but here are my runs:
194HP 178.6ft-lbs, 201.4HP 180.4ft-lbs, 202.3HP 182.2ft-lbs The first (lowest) run was made with my RH tailpipe capped, as I normally do for street driving. Taking it off gave me the extra 8HP. I hope my wife appreciates this sacrifice. Stock (120K miles) 3.2, B&B headers, Fabspeed muffler, Steve W chip. The chip isn't optimized as it was purchased setup for a Euro pre-muff and sport muffler like I used to have. I'm going to send it back for reprogramming for the headers and 93 octane, so that should help a bit. All in all, I'm pretty pleased...
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Doesn't want/need a 3.6L
Way to go Ed!
Good solid numbers. For comparison, my 3.2L was 199 whp and 182 torque with Dansk pre-muffler, Dansk single in/dual out muffler and Steve Wong chip programmed for the above. Ralph P.S. - I guess the 3.4L is now officially "on hold"? Ralph |
Hey Ralph: Wisdom is most likely going to prevail here, unless I find something bad when I drop it for the clutch, I'm going to do all the "while you're in there" stuff. Now I'll have all that money to spend on suspension of something...
Considering stock should be 207 at the crank, I'm pretty happy with the results here. Easily should be 230 at the crank. If you do the 15% math, it works to 240. I was holding up on sending my chip to Steve to redo, now I wish I'd done it prior to today.
MBruns for President
Good numbers Ed - that's very respectable
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Irrationally exuberant
Re: Dallas PCA dyno day-my results...
You can't really compare dyno numbers to factory numbers. The factory numbers were the minimum horsepower. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
