Trouble loading Pictures
Have not had trouble in the past (last about 3 weeks ago), but now get an "Error on Page" message when trying to load an image using the "Click here to upload a Photo..." link at the bottom of the page. Image is a JPG and is only 160kb.
Any suggestions??? |
I have had a problem also. I upload the photo and it says it is finished but it doesn't jump on to the message. Some pictures are fine and I don't know why. I have tried redcing them and re-scanning them but it doesn't remedy the problem. They are jpgs so I know that isn't the problem????????????
happens to me too on the larger pics
It seems there is an occasional server glitch. I was getting an "incorrect format" message repeatedly last week when trying to post a .jpg file. The same photo posted fine the next day.
The max total of pics load was 100kb. I think it still is ?
If a pic doesn't load properly I change the name. I was told here to not have any spaces between file name and .jpg after name. I find that a 60kb/300dpi pic doesn't stretch the pic beyond the initial screen. I scan pics at 300dpi. Others have said 200dpi is ok for a clear pic. Pelicanhead nostatic can answer any question on this subject I believe. Jack Olsen has said that photoshop is good for setting up pics before loading in pelican. I still don't understand how a pelicanhead can load 5 full size clear pics on one reply ? That means 20kb each ? I don't know how to do that. Wayne has said that the Pelican program may make the pic clearer than if you viewed it on your home computer only. I think I understood that. |
Along Ron's suggestions, try renaming the file with regular alpha-numeric characters; no symbols or spaces (although hyphens are usually ok).
After you upload one image, you can go back and upload add'l images. I think Wayne has a help thread somewhere. Hope this helps, Sherwood |
| All times are GMT -8. The time now is 12:16 PM. |
