-   -   Removing Tinware (http://forums.pelicanparts.com/porsche-911-technical-forum/185428-removing-tinware.html)
Ron78SC 10-03-2004 04:57 AM
Removing Tinware
Hi
I've done a search but couldn't find a definitive answer on whether I can remove the engine tinware with the engine in situ.
I started doing a general cleanup of the engine by which has progressed to me wanting to powdercoat the tin.
I've removed the bolts at the rear and side but can't see how I can get the rear section past the engine support bits.
Ron:confused:
Zeke 10-03-2004 08:58 AM
I think with patience you cna get most of it off. With the exhaust off, it should be able to be done completely, AFIK. You can always lower the engine 2-3 inches to get at another bolt. I find a 1/4 drive socket helps.
