Removing Tinware
Hi
I've done a search but couldn't find a definitive answer on whether I can remove the engine tinware with the engine in situ. I started doing a general cleanup of the engine by which has progressed to me wanting to powdercoat the tin. I've removed the bolts at the rear and side but can't see how I can get the rear section past the engine support bits. Thanks Ron
I think with patience you cna get most of it off. With the exhaust off, it should be able to be done completely, AFIK. You can always lower the engine 2-3 inches to get at another bolt. I find a 1/4 drive socket helps.
